Salt Water Communications
  • coryhenry
    • Jul 2020
    • 156
    I live in San Diego and fortunately or unfortunately (depending on how you see it) I am surrounded by salt water. This includes our local RC pond. I just received the Kilo kit from Bob Martin (thank you very much Bob) and wanted to explore ways to communicate in salt water. I came upon this research paper that describes how they developed an acoustic system for RC vehicles that is simple and intuitive using acoustics. IT looks like the form factor could be implemented in RC Submarines and I wanted to get the opinions from the experts on here. In the meantime I plan to run the antenna up through the a snorkel so I can run at periscope depth in the local pond. I have about six months left in my Middle East deployment so have time to work out the problem set :)
    Here is the link to the paper
    Thoughts?
    Cory
  • a1965l
    • 147
    That's an interesting solution. What I didn't get from the paper is how exactly they're controlling the submarine... I.E., does the receiver output standard pulses for servo control, or did they do something else? There are standard library functions for Raspberry PI that allow direct control of servos using a PI board, and that board could receive commands from this system. The other thing that would need to be solved, if this evern turned into a hobby system, is how to run multiple systems without interferenece...
      • 3547
      Thoughts?
      Cory
      Cory,
      ‘I would like to welcome you to join us when we gather at Yorba Linda regional park. Mike Dory, a early trail blazer in our hobby, lives in your area and drives up with his Type 7. He used to run in the brackish ponds around SanDiego, but you needed to keep a antenna above the surface, much like those that use 2.4 GHz today. If you are interested, pm me with your email and I will forward it to the crew at SuRon LA.
      peace,
      tom
      • QuarterMaster
        • Sep 2015
        • 1198
        Thoughts?
        Cory
        2.4GHz for the RC Submariner….the next step.
        v/r "Sub" Ed
        • coryhenry
          • Jul 2020
          • 156
          Thanks everyone for the suggestions and articles. Unfortunately the suggestions don't solve the root problem of being able to communicate underwater in salt water. Any other ideas?
            • 2754
            How about lasers? Maybe design a control system similar to those infrared controllers for toy RC helicopters. As IR is blocked by water we need swap out the IR diode with a laser (green).
            • coryhenry
              • Jul 2020
              • 156
              I did see some research with laser comms. They do require a sophisticated tracking and aiming mechanism to ensure the transmitter and receiver are always in alignment. The IR systems have a very wide beam so don't really have that problem.
                • 2754
                Electronics are beyond me but how about a system that uses acoustics? Going back to the IR remote, how about swapping a piezoelectric transducer to the IR diode to send out "pings" which corresponds to control commands. An piezoelectric receiver on the boat listens for the pings
                • Scott T
                  • May 2009
                  • 378
                  Not sure if this could be done but what if you made a repeater radio that could plug in your radio receiver then translates the received signal and sends it out as 75 hz. You could then buy the latest greatest radio and plug its receiver in the repeater radio. While you are at it add WIFI so you could send commands from a phone. Phones don't show up well in sunshine though.
                  • coryhenry
                    • Jul 2020
                    • 156
                    This is the architecture I was thinking could work.
Name:	Acoustic Control.jpg
                      • 2754
                      You could eliminate the radio and just hook a handheld game controller directly to the arduino.
                      • coryhenry
                        • Jul 2020
                        • 156
                        You are absolutely correct, I just wanted to make a package that could be used with any system and keep it comfortable for the normal RC user, not always a gamer :)
                          • 2754
                          Check out this robot fish https://www.google.com/url?sa=t&sour...=1594983359058
                          • Bob Gato
                            • 831
                            How freaking cool is that! Its not a far stretch of the imagination to see the controls interfaced with an above surface link. And secondary-the hydraulic propulsion is way cool (good for Sci-fi and future sub models)
                              • 2754
                              swims like an injured fish, imagine a shark suddenly gobbling it up.
