Where are you sourcing your oilite bearings/bushings?
  • RazorAntilles
    • Oct 2024
    • 22
    The best I've been able to find are 1/4" sleeve and flange bearings and bushings, while two online sources that allegedly carry what I'm looking for have incredibly arcane ordering processes that I haven't yet figured out how to properly get through.
    I'm looking for 3/16" inner diameter as well as 1/8" inner diameter (two LAs and one Typhoon... so far...).
  • TuptubBuilder
    • 109
    If you reside in the USA, McMaster-Carr. Shipping is expensive so I batch my orders. Click image for larger version
ID:	190535 Click image for larger version
ID:	190536 Click image for larger version
    • RazorAntilles
      • Oct 2024
      • 22
      You are my hero of the day, good sir: not only am I in the US, I can actually drive to their facility and pick up orders as I'm local to their warehouse.
        • 645
        McMaster-Carr is more expensive, but their various items are comprehensive and good and can be the only place to obtain part (s).
        There are in many areas' local distributor storefront warehouses. You can order online and they can ship to you, or better, save shipping and drive down t the local brick mortar store. They may not have the part there, but it's in their system and they will ship it to your nearest location for you to pick up. it is often faster and cheaper than home delivery.
        The stores have a clean immaculate auto supply store atmosphere there. Tell them what you are building it for, (rc subs and you become an instant 15-minute celebrity...lol.). The people there are very helpful and friendly.
          • 2434
          PTFE tubing makes great bearings. Can get a metre on ebay for a couple of quid,enough to make dozens of bearings.
            • 1946
            Great idea. I find Teflon problematic to glue to, however. You'd have to make a sleeve or something to capture the teflon lining.
              • 645
              Maybe grind a grove in the polytetrafluoroethylene (Teflon), then design and 3D print a sleave to slide around the Teflon part? Create a line of Teflon shaft bearings?
              • TuptubBuilder
                • 109
                If it isn't too much trouble, could you provide a URL? I am interested in dimensions and tolerances. I will note that, back in my day, 300 series stainless steel shafts did not work well with sintered bronze, oil impregnated bushings. Also, what do you do when a flanged bearing is required?
                  • 2434
                  Just search eBay for ptfe tubing, I purchased my tubing ages ago and the vendors come and go. They sell it by the metre, used a lot for Bowden feeds on 3d printers amongst other things. Bear in mind the tubing needs reaming to size. If you want ready to fit plastic bearings and ones with flanges then IGUS make some nice ones. E.g. https://www.igus.co.uk/plain-bearings-shop
                  • TuptubBuilder
                    • 109
                    Thank you for the information. I have successfully used IGUS bearings back in the day. It might be worth noting that reaming should occur after press fitting the bearing material. I have found that an expandable reamer is necessary with plastics and it must be very sharp. Otherwise it just pushes the material out of the way. As for the bronze bushings, seating in a compliant material such as plastic and using a slight interference fit should not require any post processing to maintain the proper ID. If it does, ball broaching, not reaming is the correct method so as not to smear the sintered surface.
                      • 2434
                      I find a normal reamer sufficient, I only tend to work with shafts sizes of around 2-4mm diameter, and with the speed and loads involved things are very forgiving.
