I spy!
    Thanks 639mpa. As to the Russian submarine sensors, I believe that this submarine was a test bed for the SOKS sensor system as used on the Akula but Ive also seen some on a Victor boat.Click image for larger version
ID:	73401Click image for larger version
Name:	Akula sail zoom.jpg
ID:	73396Click image for larger version
ID:	73397Click image for larger version
ID:	73398Click image for larger version
ID:	73399Click image for larger version
      I SPY a Russian submarine with some unusual features. Can anyone place it?
        • 13987
        #348
        I've seen something like this on one or more SKIPJACK's: either a Mk44 or Mk46 weapon transducer section set into the leading edge of the sail -- mine avoidance sonar or some such, I think.
        The unit on the port side of the above photo looks like a torpedo transducer. Same thing, maybe?
          Deep Dark secrets from the Evil Empire. This sail is attached to Yankee K-403 Kazan. It was de-missletized and made into the sole Yankee Pod. According to various sources it was then used to evaluate various submarine systems including the infamous Pod atop the rudder, later used on Sierra and Akula. As well as various sonar systems.
Name:	Yankee pod side.jpg
ID:	73479Click image for larger version
Name:	Yankee pod front quart.jpg
ID:	73480Click image for larger version
Name:	Yankee Pod from stern.jpg
ID:	73481Click image for larger version
Name:	Yankee pod bow.jpg
ID:	73482In this picture you can barely see something unusual on the nose. The picture was very dark. I lightened it up as much as I could. Whatever it is they covered it up with a tarp in the last picture. Sneeky Devils.Click image for larger version
Name:	Yankee pod 1.jpg
            Maybe that deal on the nose is a test bed for this, the B90 Sarov.
ID:	73484Click image for larger version
              If you go back up and look at the pictures posted on 10-5 at 10:45 am, the first picture shows a view from the port side. Note how long the sail is. Much longer in length than the normal Yankee. Alot of extra room for extra goodies.
                I SPY.............something unusual. Notice in this picture at the bow where the superstructure meets the hull. Looks very different than the other Ohios that I have seen. Does anyone else see it?
Name:	Ohio class funny superstructure.jpg
                  Perhaps it was an optical illusion. The picture in the first post seemed to show a larger angle in the way the superstructure fared into the hull. But this one pretty much shows the same thing.Click image for larger version
Name:	USS Alabama at Bangor.jpg
ID:	73614Click image for larger version
Name:	USS Alabama close on hull.jpg
                    Lets see if anyone has been paying attention. I Spy an unusual feature on this submarine. Who can tell us what it is?Click image for larger version
Name:	Dont waste your time looking here.jpg
ID:	74226Click image for larger version
Name:	couldnt tell you.jpg
                      I tried to look at the writing on the far boat, and I got a little 'flag' come up and say ' Don't waste your time looking here!" The writing said MARCHE
                      Where is the sail on that boat? I guess you're referring to the bump on the superstructure?
                        • 13987
                        #356
                        PARCHE?
                        Inactive-ship facility.
                        Batteries have been pulled from two of these boats.
                          Yes, the Conning Tower is missing on the boat on the right. It is the Parche. Actually I was referring to the Bulge on the stern of the middle boat. I will give you a clue. The middle boat is the Spinax.
                            Dave, the reason why you say that the batterys have been pulled is because they are sitting so high in the water? If not, how else can you tell?
                              Is it new sonar and fire control equipment?
                                Heres another clue: Its related to ...................................safety
