New Project - What am I?
New plan for the rear hatches et al.. I'm going to scribe them rather than inlay brass. Its soooo much easier to do and the end result looks better, (once its done right). So, herewith todays efforts. I've closed the gaps in the hull and begun the railings.
OK, Hardrock.
You've learned your lesson with this project: Crap in, crap out. In other words, if the master is not perfect, you will be compelled to make corrections on each and every copy produced from the tools. A lesson DavidH is all too familiar with. He's fighting the same battle as you are.
Get the master right, and the produced parts will come out right.
I'm here to instruct. I'm a vital resource. Use me!
Do we have to go back to model-building 101 here? I'm game. Tell me your weaknesses in this game and I will instruct you on how to overcome those weaknesses.
The Horrible
Who is John Galt?Comment
Keep talking...voice activated tracking has been enabled and a small (ish) shaped charge tipped missile is heading your way as an indication of my high regard for your timing. Could you have told me this BEFORE I started? I'm going to start again. This thing is giving me the ****s - its not just the scribing its the subtle variances in symetry that I keep finding.Comment
I had the same with mine......had to correct the stern it was oval instead of round due to finishing the masters halves separately instead of assembled together.
Not a big deal when it a one ping only model…........but you are in trouble when somebody asks you to make a copy for them….........that’s why I always say the Akula is not good enough for reproduction.
We learn and don’t make mistakes twice. We post our mistakes here openly so others can learn.
But be aware that HWSNBN will ask you to make a copy of your work….........you know you can’t give what he what’s because it’s not flawless as it should be…….........but then on the other hand you want to because he ALWAYS helps you out.
The result is that you feel really bad about it…….........and it pushes you to make your next model as close to perfection as you can.
Well that’s the effect that it has on me.
Grtz,
BartLast edited by bwi 971; 06-13-2016, 10:51 AM.Practical wisdom is only to be learned in the school of experience.
"Samuel Smiles"Comment
Yeah, too late to tell you now, but you fell down the rabbit hole during the lay-out process -- the job of translating two-dimensional documents (plans) to the three-dimensional blanks that will be formed into your finished master. And that's where I'll start: 'lay-out'. Your problem of symmetry and accuracy of part/engraved line/ transfer from drawing to work will be addressed. I'll get to it this week. May I post it to this thread?
I've engaged all anti-missile batteries, all outfitted with depleted cream-pie warheads (denser than U-238), all fused for direct hit. Game on, pal!
The Horrible
Although I am not happy with the molding process (and with the many faults that I later discovered and had to fix), the end result in a "one off" submarine is really quite satisfying. I started this thing with a drawing, some foam and razor saw. Have a look at it now! Its a wonderful thing to learn new and interesting stuff.
I can't quite believe it but she is here, sitting on my desk finished - except for the SD which I will start work on shortly. This has been instructive, but the most sage advice that I have received thus far is "garbage in, garbage out". As a "one off" she is, well, one of a kind. I remember the old line from boot camp that went, "This is my rife, there are many like it but this one is MINE". And this sub is mine; warts and all. Once I've figured out how to configure an SD that works I'm going to start again with a new (and more accurate) plug. There will be a new Piranha and you won't have to virtually rebuild the thing to make a decent sub from the hull that I supply - eventually.
