New Project - What am I?
    • 2759
    Interested in how you'll make the stern planes operational within that narrow stern cone. With the rudder you could go with an external control rod. With the stern planes it'll be tight.
    How about fixed stern planes with operational bow planes?
      I'm going to have about 1/4" ID where the control rod for the stern panes enters the body of the sub - that's more than enough. (on the Japanese Type A I had less than 1/8" and it worked quite well). I'm thinking of making them full flying so that I have some control; with the separation line running parallel with the hull, through the line of the original stern plane. The bow planes will also be operational as will the masts.
        Fixed stern planes and operational fore planes is also a very good idea and I might come back to that if it all goes to ****.
          In the middle of the fill, sand, fill, sand, swear, fill, sand cycle. Its beginning to look like a Piranha but lots more sanding to do.Click image for larger version
ID:	114243Click image for larger version
ID:	114244Click image for larger version
            • 2759
            Why do I suddenly have a craving for a corn dog?
              Ha ha. No doubt that should be the NATO reporting name for something.
                • 2759
                That's an interesting impeller- looks like a metal washer...
                What's the inside diameter of the nozzle?
                  14 mm. Waiting for the propellor to arrive.
                    CORN DOG RISING! Engaging in appendage play. Soooooo much fun. I'm also making a jig to ensure that the damn things go on straight as well.Click image for larger version
ID:	114269Click image for larger version
ID:	114270Click image for larger version
                      • 2759
                      Is this a one off or will you be making muliple hulls?
                        Probably make a few of these. I'm using it for practice. The last one was OK but pretty clunky. I'd like this one to be a bit more refined - hence the small size; not too much to get overtaken by.
                          Getting on with the appendages. The prop arrived and is a good fit.Click image for larger version
ID:	114284Click image for larger version
ID:	114285Click image for larger version
                            The Corn Dog is coming along. Bow planes next. Does anyone know a simple method of etching brass. There are lots and lots of grills to done on this thing.Click image for larger version
ID:	114289Click image for larger version
ID:	114290Click image for larger version
                              • 2759
                              Etching brass using saltwater
                                Thanks. Looks promising.
