New Project - What am I?
    Can't resist doing this one.Click image for larger version
    • 12255
    VICTORE?
    • bwi 971
      • Jan 2015
      • 896
      project 865 Piranha Проект 865 «Пиранья»......and if you have the plans please tell me were you got them from.
      Grtz,
      Bart
      "Samuel Smiles"
        • 3545
        will this help? Click image for larger version
        Last edited by trout; 11-23-2015, 04:33 PM. Reason: Getting the image correct..............GRRRRRR
          • 3545
          will this help?
          • bwi 971
            • Jan 2015
            • 896
            Thks Tom appreciate it.....I also have this one but I don't have the frames.
            Grtz,
            Bart
            "Samuel Smiles"
              Grtz,
              Bart
              Correct. Give the man a cigar! In 1/96 scale it will be 293 mm long. Just big enough to play with in the bath. (As the actress said to the Bishop).
                I have one now and a full set coming later.
                  Finally got started on this build. It will great fun in the bath tub but not much use anywhere else.
ID:	114150Click image for larger version
ID:	114151Click image for larger version
                    Nice video of the Piranha.
                      • 2735
                      Any idea if the 2" Kilo SD will fit inside this?
                        Nope. The internal diameter will be around 46mm so a 2" SD will be too big; a 1.25" SD will fit nicely however.
                          The foam has been shaped (in a rough kinda way) and glassed with two layers of woven cloth. Once its dried I'll sand it down and fill in the dents.Click image for larger version
ID:	114172Click image for larger version
ID:	114173Click image for larger version
                            • 2735
                            Will this be a dynamic or static diver?
                            How about a 1.5 " SD?
                              I'm thinking static diving 1.5 will be very thigh and probably very short - in the order of 4.5" where as a 1.25" SD can be 7.5" long. I started on the appendages today. This is the ridder and upper support.
