New Project - What am I?
    Can't resist doing this one.Click image for larger version
    VICTORE?
    • bwi 971
      • Jan 2015
      • 940
      project 865 Piranha Проект 865 «Пиранья»......and if you have the plans please tell me were you got them from.
      Grtz,
      Bart
      "Samuel Smiles"
        will this help? Click image for larger version
        Last edited by trout; 11-23-2015, 03:33 PM. Reason: Getting the image correct..............GRRRRRR
          will this help?
          • bwi 971
            • Jan 2015
            • 940
            Thks Tom appreciate it.....I also have this one but I don't have the frames.
            Grtz,
            Bart
            "Samuel Smiles"
              Grtz,
              Bart
              Correct. Give the man a cigar! In 1/96 scale it will be 293 mm long. Just big enough to play with in the bath. (As the actress said to the Bishop).
                I have one now and a full set coming later.
                  Finally got started on this build. It will great fun in the bath tub but not much use anywhere else.
ID:	114150Click image for larger version
ID:	114151Click image for larger version
                    Nice video of the Piranha.
                      Any idea if the 2" Kilo SD will fit inside this?
                        Nope. The internal diameter will be around 46mm so a 2" SD will be too big; a 1.25" SD will fit nicely however.
                          The foam has been shaped (in a rough kinda way) and glassed with two layers of woven cloth. Once its dried I'll sand it down and fill in the dents.Click image for larger version
ID:	114172Click image for larger version
ID:	114173Click image for larger version
                            Will this be a dynamic or static diver?
                            How about a 1.5 " SD?
                              I'm thinking static diving 1.5 will be very thigh and probably very short - in the order of 4.5" where as a 1.25" SD can be 7.5" long. I started on the appendages today. This is the ridder and upper support.
