Recovering lost Subs
    Wading in with a face mask and scuba tank as a last resort what can you recommend as a good means of locating/recovering a lost sub; marker bouy, marker dye, pinger/locator beacon etc.?
  • junglelord
    Banned
    • Jan 2009
    • 300
    Clear water...:p
    I would try to keep several items in mind when I take my subs out this summer.
    Clear water that is not too deep
    ADF with failsafe
    Lipo protector with failsafe
    Other then that, I guess my brother and his scuba equipment.
    • toppack
      • Nov 2008
      • 1124
      Yes, With most submarines it's very difficult to have an attached marker-buoy, that will detach and float, like you can with surface-ships. But it would be possible to have conning-tower loose, so it would float, with a string attached.
      I did that on my speed-boat that very often thought it was a submarine. :D
      Of course the safest thing is build it with Positive flotation, so it has to be forced to dive, and it will always return to surface, but I guess that can't be called a true submarine. ;)
      Rick L.
        Two points here. If the conning tower were able to float, surely it would effect the overall trim of the boat as soon as it let loose? Never put foam above the surfaced waterline, therefore the conning tower is out of bounds for this.
        I like the idea of trimming the boat so that with ballast tank full of water, only the tip of the sail or the Snort is visible. Lets call that 'lower trim'. In that case, the boat should surface to that point if there is a failure etc. To make the boat dive, flood the ballast tank, engines on and dive planes down. Stop engines and the boat will surface to 'lower trim'. Blow the ballast and it will surface to correct waterline. Neat.
        • toppack
          • Nov 2008
          • 1124
          Yes, now that I think about the loose tower would never work anyway, it would be coming off every time you got it below surface, unless you had a water soluble material holding it, that dissolved after a while, but that's getting way too complicated and maintenance-intensive. :rolleyes:
          Rick L.
            • 2641
            Trimming for positive buoyancy won't help you if it gets stuck in weeds or springs a leak.
            Experience has proven that the most reliable method of locating a sunken model submarine is by sound. Sods law says your boat goes down in a muddy stretch where you can't see bugger all.
            Pingers are great.
            • RAY
              • Jan 2009
              • 31
              Hi Guys.
              Only lost one boat,it was a surface vessel,I came up with the following.
              One thunder tigre neptune with a 0lux camera,length of tube attached to SB1 carrying a grapple made from three sea fishing hooks with a float attached,sliding fit in tube and a spool of twenty pound fishing line.
              The camera was cheap on offer at maplins comes with a twenty metre cable power supply and minitor.
              SB1 is tethered so not much chance of that getting lost.
              Spent two days looking for my boat but I got it back.
              Ray
                • 13985
                [QUOTE=RAY;2794]Hi Guys.
                Ray
                Now THAT is neat!
                Did you use float to help buoy the coaxial cable? What was the maximum depth you could maneuver with the umbilical? And how was maneuverability overall with the umbilical?
                Details, ******, I want details!
                Well done, sir!
                • Slats
                  • 1776
                  Pingers are great.
                  Andy, where from and how much?
                  J
                  sigpic
                  • RAY
                    • Jan 2009
                    • 31
                    [quote=Merriman;2795]
                    Originally posted by RAY
                    Hi Guys.
                    Ray
                    Now THAT is neat!
                    Well done, sir!
                    Hi David.
                    Details you shall have.my lost boat was in about twelve feet of water,I saw it go down but sods law they never go straight down hence two days to find it.
                    The SB1 has been called a toy by a number of modellers I prefer to call it a tool, the ready made virsion comes with poor radio fitted,if you buy the kit and good radio it costs about the same, and you know its going to work.
                    It will happily pull the coax without any floatation,it will also go down beyond ten metres.
                    You have to put a float on your grapple in case it comes off what you have attached it to,you dont want to be pulling the bottom of the lake up.
                    The camera and monitor will run continuous for at least four hours.
                    The spool of line is a standard spinning reel job that fits on a spigot, once you have hooked your boat (prop) or something just back off,it will unwind all the way back to you.
                    Just remove spool from SB1 fit to reel wind it in,spool of line and grapple ready to go again....KISS.
                    And I for got to add,I had as much fun recovering my boat as I would running it,if the navys can do it real time why not we do it,model subs are not cheap.
                    Ray
                      • 13985
                      Thanks, Ray. Man, that's neat!
                        • 2641
                        J
                        Dave Forrest makes them. Not sure how much they are currently, but they're not expensive. You need to make a hydrophone too, if you haven't got one already. Dave used to supply kits for those, but no longer does so. Instead he supplies a CDROM with all the information on it.
                        Are you on Facebook?
                        • RAY
                          • Jan 2009
                          • 31
                          You can make a simple hydrophone from a piezo buzzer,a pair of plastic discs and an "o" ring,you would need a pre amp and headphones,it isnt hard to make the net is full of ideas.
                          Ray
                            Would be great if you can incorporate a hydrophone on the SB1. You can use it to home in on the sub even in murky waters. The grapple system would be sufficient on those WWII era boats with their railings and propeller guards but a bit useless on modern boats with their slick profiles. Here you can use a retractable loop that can be used to snag either the sail or prop.
                              • 13985
                              Hi Guys.
                              Ray
                              [ATTACH]701[/ATTACH]
                              [ATTACH]702[/ATTACH]
                              [ATTACH]703[/ATTACH]
                              [ATTACH]704[/ATTACH]
                              I'm bumbing this back into the light. Ray Williams is a frig'n genius!
