1/72 Revell Of Germany Type-9 .... It Starts!
    • 3705
    #76
    What is in your prep-sol? And you use it for plastic only or?
    • crazygary
      • Sep 2012
      • 610
      #77
      Really like your bright-eyed supervisor!!
      Looks to be on top of things!! ( No pun intended!)
      A very Merry Christmas to all!!
        • 13831
        #78
        Tom:
        Prep-Sol is a mild hydrocarbon based de-greasing liquid. Marketed at the car refinishing crowd. Strong enough solvent to cut grease and dirt, but mild enough to not melt or craze polystyrene and most other plastics. I scrub kit parts with a Prep-Sol saturated abrasive pad.
        As you know, all injection formed kit parts retain a bit of the sprayed on mold-release agent applied to the metal tools used to form the trees -- the amount of retained mold-release on the surface of the parts being a function of plant protocol, and where along the application phase your parts were shot. Always assume your parts were shot immediately after the last misting of mold release and are heavily coated with glue-filler-putty-primer-paint inhibiting gunk.
        Hence the need to clean the surface of all polystyrene, GRP, and resin kit parts.
        Using Prep-Sol is easier than scrubbing the parts with scouring powder, stiff brushes, and lots of water.
        Crazy:
        Mr. Cat has been trained to rip my face off the instant he see's me slacking off in the shop. Ellie's idea.
          • 3615
          #79
          Much better than the cattle prod she was using on you...
            • 3615
            #80
            • reddevil
              • Jun 2009
              • 346
              #81
              Simply amazing.
                Tom:
                Crazy:
                Ahh, "better living thru chemestry" DuPont has the solution for everything. My cat loves my work space. so many things to help me with. Best stress relief is having someone to chat to while your workin, that dont ask questions and is really intrested in the projects at hand.
                • Buellman1
                  • 93
                  #83
                  Dave,
                  If I have a type 212 driver that's currently in my nautilus, could a double shaft output motor housing be swapped in place to run this hull? I'm thinking along the lines of having a module to swap reciever but have duplicate servos and esc, etc.
                    • 13831
                    #84
                    Buellman:
                    You mean outfitting with 2" SD you have with a two-motor motor-bulkhead as used with the Type-7 and SEAVIEW? Not enough ballast tank on the SD you have to float the Type-9 properly. Other than that, a viable concept.
                    However, I don't sell discrete stuff anymore other than the 3.5 SD motor bulkheads and cylinder kit. When we did, it turned into a logistical nightmare for the Caswell people.
                    Von:
                    No such luck with my cat-from-hell. He sits in a dark corner of the shop, his beady little red eyes ever watching for an opening. It's awful!.... simply awful!
                    • Buellman1
                      • 93
                      #85
                      Ok Dave,
                      I just now realized your going 2.5inch in it. What about putting the gato drive unit into the shorter tube? But I guess that goes with the issue with caswell only selling complete units too?
                      One thing I noticed in the prototype subdriver pictures. I'd rather see the check valve vent go into the battery side dry space. My two cents.
                        Originally posted by Buellman1
                        Dave,
                        What do you have here, and what exactly do you need?
                          • 13831
                          #87
ID:	89206Click image for larger version
ID:	89207Click image for larger version
ID:	89208Click image for larger version
ID:	89209Click image for larger version
ID:	89210Click image for larger version
ID:	89211Click image for larger version
ID:	89212Click image for larger version
ID:	89213Click image for larger version
ID:	89214Click image for larger version
ID:	89215Click image for larger version
ID:	89216Click image for larger version
ID:	89217Click image for larger version
ID:	89218Click image for larger version
ID:	89219Click image for larger version
ID:	89220Click image for larger version
ID:	89221Click image for larger version
ID:	89222Click image for larger version
ID:	89223Click image for larger version
ID:	89224Click image for larger version
ID:	89225Click image for larger version
ID:	89226Click image for larger version
ID:	89227Click image for larger version
ID:	89228Click image for larger version
ID:	89229Click image for larger version
ID:	89230Click image for larger version
ID:	89231Click image for larger version
ID:	89232Click image for larger version
ID:	89233Click image for larger version
ID:	89234Click image for larger version
ID:	89235Click image for larger version
ID:	89236Click image for larger version
ID:	89237Click image for larger version
ID:	89238Click image for larger version
ID:	89239Click image for larger version
ID:	89240Click image for larger version
ID:	89241Click image for larger version
ID:	89242Click image for larger version
ID:	89243Click image for larger version
ID:	89244Click image for larger version
                            • 13831
                            #88
ID:	89246Click image for larger version
ID:	89247Click image for larger version
ID:	89248Click image for larger version
ID:	89249Click image for larger version
ID:	89250Click image for larger version
ID:	89251Click image for larger version
ID:	89252Click image for larger version
ID:	89253Click image for larger version
ID:	89254Click image for larger version
ID:	89255Click image for larger version
ID:	89256Click image for larger version
ID:	89257Click image for larger version
ID:	89258Click image for larger version
                              The amount of work that this Guy gets done in such a short period of time is just amazing.
                                • 13831
                                #90
                                Key ingredients:
                                1. Supportive wife
                                2. Well outfitted work-space
                                3. Dedication to all aspects of the Craft
                                4. Patient Boss and clients
                                5. A society that rewards those who produce useful goods or service, and kicks the **** out of those who don't (wishful thinking) ... Ayn Rand, call your office
