A day in The Cave
    • 13983
    #31
ID:	84179Click image for larger version
ID:	84180Click image for larger version
ID:	84181Click image for larger version
ID:	84182Click image for larger version
ID:	84183Click image for larger version
ID:	84184Click image for larger version
ID:	84185Click image for larger version
ID:	84186Click image for larger version
ID:	84187Click image for larger version
ID:	84188Click image for larger version
ID:	84189Click image for larger version
      • 13983
      #32
      tonight's work:
ID:	84303Click image for larger version
ID:	84304Click image for larger version
ID:	84305Click image for larger version
ID:	84306Click image for larger version
ID:	84307Click image for larger version
ID:	84308Click image for larger version
ID:	84309Click image for larger version
ID:	84310Click image for larger version
ID:	84311Click image for larger version
ID:	84312Click image for larger version
ID:	84313Click image for larger version
      • reddevil
        • Jun 2009
        • 346
        #33
        Geniuses at work.
          • 13983
          #34
ID:	84343Click image for larger version
ID:	84344Click image for larger version
ID:	84345Click image for larger version
ID:	84346Click image for larger version
ID:	84347Click image for larger version
ID:	84348Click image for larger version
ID:	84349Click image for larger version
ID:	84350Click image for larger version
ID:	84351Click image for larger version
ID:	84352Click image for larger version
ID:	84353Click image for larger version
            #35
            Very productive day in the cave
              Must be burning the midnight oil. Thats one dedicated sub guy.
              • SSBN659
                • 418
                #37
                A question for David. Why do you scribe through the corners of a square/rectangle? Is it easier that way? Ops, that's two questions.
                SSBN659
                  • 13983
                  #38
                  SSBN659
                  Hey, Roger
                  (your photo of that SSBN in dry-dock provided the dope I needed for Moebius to get the SKIPJACK MSW gratings right -- thanks for that)
                  The over-strikes (engraved lines extending past the engraved items corners) is a consequence of dragging the scratch-awl with an even pressure into and slightly past the items corner -- if I endeavored to stop the engraving process at the corner I would slightly vary the speed, pressure and angle on the tool, producing a non-uniform depth and width of cut. Better to drag on past the corner, and fill the over-strikes with putter later than to wind up with and engraved item of varied width and depth.
                  Anyway, since almost all engraved items featured a tight radius at the corners -- not a tight right-angle intersection -- I had to come back with a radius scribe and engrave each corner again anyway.
                  Unless you use a dedicated scribing stencil, like these:
ID:	84359Click image for larger version
                  This is why God gave us Bondo and air-dry touch-up putty, pal.
                    LOVE THOSE TEMPLATES!! You have the neatest gadgets. What is that? A molded piece of GRP?
                      • 13983
                      #40
                      Yes. First, after getting the model into primer gray, I give it a few coats of PVA, then wax it, then lay up the stencil blanks out of GRP. Remove them, soak the model in water to melt off the PVA, punch holes into the blanks, and scribe away.
                        • 13983
                        #41
                        • SSBN659
                          • 418
                          #42
                          David, your scribing technique is another one of your neat tricks I'll copy shamelessly. Thanks for the tip.
                          SSBN659
                            • 13983
                            #43
ID:	84373Click image for larger version
ID:	84374Click image for larger version
ID:	84375Click image for larger version
ID:	84376Click image for larger version
ID:	84377Click image for larger version
ID:	84378Click image for larger version
ID:	84379Click image for larger version
                              • 13983
                              #44
ID:	84391Click image for larger version
ID:	84392Click image for larger version
ID:	84393Click image for larger version
ID:	84394Click image for larger version
ID:	84395Click image for larger version
ID:	84396Click image for larger version
ID:	84397Click image for larger version
ID:	84398Click image for larger version
ID:	84399Click image for larger version
                                HA! You guys are double teaming that thing.
