Weathering colors below the waterline on nuclear subs
  • Timothy L
    • Sep 2024
    • 217
    I hope this information may be of interest to those of you want to weather a nuclear sub at and below the waterline.
    • The information presented below was generated by AI. After reviewing some of David Merriman’s weathering techniques / descriptions I did some exploring to see what colors might be seen in bio-fouling on a nuclear sub after 2-3 months at sea. I suspect this info to be accurate but if any nuclear sub veterans want to offer additional clarification or corrections, please do so.
      I have never been able to find photographs of how a sub might look immediately after it is put into dry dock - most likely because the colors change within days due to drying, oxidation, etc.
      Here we go:
      When a modern nuclear submarine returns from a multi-months at sea the hull is often heavily colored by shades of muddy green, brownish-yellow, dull grey, and chalky white.
      Because ballistic missile submarines (SSBNs) and fast attack submarines spend months submerged at very slow speeds to maintain acoustic stealth, they become a prime habitat for marine organisms.The colors progress through distinct biological phases over a three-month patrol timeline:
      1. Microfouling Phase (Weeks 1–3)
      • Dull Brown & Light Amber: This layer consists of a microscopic biofilm or "slime" made of bacteria and diatoms. It leaves a slightly slippery, brownish-bronze tint over the black anechoic rubber tiles of the submarine.
      2. Soft Macrofouling Phase (Weeks 3–8)
      • Vibrant Grass Green to Olive Green: As the submarine cruises slowly through the photic zone (where sunlight penetrates), various species of marine algae and seaweed take root.
      • Muddy Brown & Dark Mustard: Filamentous brown algae accumulate on the flat upper decks, the sail (tower), and the control surfaces where water flows slowest.
      3. Hard Macrofouling Phase (Weeks 8–12+)
      • Chalky White & Pale Cream: Hard-shelled organisms like acorn barnacles and tube worms begin attaching tightly to the hull. Their calcified shells create a stark, speckled white texture against the dark hull.
      • Dull Grey & Translucent Pink: Aggregations of bryozoans (moss animals), small anemones, and tunicate colonies cluster in unpainted or recessed areas, adding a patchy greyish or flesh-toned coloration.
      The "Algae-Caked" Reality
      The intensity of these colors depends heavily on whether the patrol took place in warm, shallow waters (which accelerate growth) or cold, deep oceans. When Royal Navy Vanguard-class or US Navy Ohio-class submarines return from record-breaking deployments, they are often described as looking completely "caked in green and brown slime" from bow to stern, requiring extensive diver cleaning or dry-dock scraping to restore their hydrodynamic and acoustic efficiency
      Biofouling Overview (3 Months at Sea)
      Growth Type Dominant Colors Typical Locations on the Submarine Resistance to Speed
      Bacterial Biofilm & Diatoms Golden-brown, light amber, translucent slime Everywhere across outer hull & fairings Moderate (sloughs at high speeds, quickly reforms)
      Green Algae ("Grass Skirt") Bright grass-green, olive-green Waterline, topside casing, sail edges, sail bridge Low (scoured off at high speed; dies/powders when dry)
      Brown / Red Filamentous Algae Dark brown, rust-red, reddish-purple Low-light zones, flood vents, casing skirts Moderate
      Juvenile Barnacles & Tubeworms Chalky white, pale gray, cream Sonar dome base, rudder recesses, propulsion shrouds High (strongly bonded to acoustic rubber/metal)
      Bryozoans & Tunicates Off-white, pale yellow, dull orange Flood ports, trim tanks, protected hull recesses
      AGAIN this info was generated by AI so perhaps it is only a starting point.
Name:	images - 2026-08-23T195616.556.jpg
ID:	197207 Click image for larger version
ID:	197208 Click image for larger version
ID:	197209 HMS Vanguard after 6 month patrol
    • Timothy L
      • Sep 2024
      • 217
      Very interesting photos - thank you for posting. There appears to be a pattern most notably on the stern. Would those be the anechoic tiles? I I am also wondering if the sub had been on the surface for a while causing some of the greener fouling to pale? By any chance do you know where the six month patrol would’ve taken the sub? Great photos.
      • CC Clarke
        • Aug 2020
        • 314
        There are troves of drydocked submarine pictures with bio-fouling on the hulls available online. In Pearl, we had green growth a foot long ringing the waterline. Once scrubbed off by commercial divers, we gained three knots.
        The region the boat operates in and frequency of cleaning determines the type and amount of growth. Once in drydock, most US boats are a light green/white color when the hull dries and the sun goes to work. Hydro-blasting takes it off prior to painting.
        Russian submarines can get pretty grungy waiting for funding for cleaning. The Brit boats above will also turn a whitish color when the marine growth dries out and smells to high heaven! I would hate to have to blast out the ballast tanks after the extended patrols they make.
Name:	Permit Scum Line.jpg
ID:	197214 Click image for larger version
        Rub marks from tugs and camels on the sides, but typical white residue when the hull dries.
Name:	Tenn in KB.jpg
        Tennessee in KB Drydock drying out as the basin is pumped out. They had an elevator in theirs! At Bangor we trudged up and down those stairs, often loaded with tools and test equipment.
Name:	Victor III Stern.jpg
ID:	197216 Click image for larger version
        A Victor III showing their highly evolved maintenance procedures.
        • Timothy L
          • Sep 2024
          • 217
          Great insight CC Clarke - thank you. It brings into to focus a whole new aspect (to me) of submarines operation - the tremendous maintenance challenges! Great photos and comments.
            • 915
            Thank you very informative as always. These are very useful intelligence clues too I'm sure that Navy's use also. The USS Guardfish photo, I recognized the yard background as Mare Island NSY, Vallejo California. Apri 1983. Her history shows she was indeed in the Yard for maintenance there that year...
            I wonder how movie audiences would have reacted to seeing USS Permit in those dry dock scenes ("Ryan! Who let you in here?") scenes filmed in SanDiago at their subbase drydock (Hunt for Red October) had filmed the boat 'with the bark on'. lol. I heard cleaning out the Mud tanks and the reactor cooling discharges was the worst. Sea creatures liked the warmer cozy water while riding. Divers cleaning sometimes found surprises living there.
            Personally, I just can't have grungy models, some light crud maybe. LOL
