HMS X-Class Stickleback Midget Submarine
    • 1937
    #46
    How about those UV resin you cure with a UV flashlight.
    Thank you Romel,
    I do not have access to a UV light nor do I have the resin required. I will go with Bob's suggestion, and use either epoxy or superglue.
    "Firemen can stand the heat."
      • 3504
      #47
      Thank you Romel,
      No problem.
      Just in case... Click image for larger version
        • 1937
        #48
        Things might be changing!
ID:	177766 Click image for larger version
        It's been about 5 years ago I received a partial 2" sub driver from David M. It was sort of set up to be used on my 1:77 scale Nautilus that I built back then. I did use it for the Nautilus, but I had some other parts and pieces that he sent me that I think will work on my Stickleback!? I will need to add another servo for the dive planes. But the good thing is I have a VEX receiver inside. I have 2 VEX Transmitters with extra modules, so I am in business with this new set up. Thanks to David M.
        I have been having some issues with my eyes, and I have an appointment today for some testing, so I will be of the blog for a while!
          • 1937
          #49
          Got a little building done today!
          Mounted the stern shaft bushing for the propeller shaft.
          Now that I have all the brass sleeves and control surface rods sized and cut, I can now secure the stern section to the rest of the bottom hull.
          • Scott T
            • May 2009
            • 403
            #50
            How about a tire valve stem or form some silicone to plug the hole and wrap the antenna. Similar to how they make the flame shape on a LED votive candle.
ID:	177832Click image for larger version
              • 1937
              #51
              Scott T.
              Not sure what the purpose of what you are trying to achieve here!?
              • Scott T
                • May 2009
                • 403
                #52
                You are planning to glue a tube for your antenna to your watertight compartment. So suggested other options. The tire valve has gaskets and threaded barrel to make a watertight seal. Using silicone you could seal the tubes you have together with a more flexible connection. Or just using silicone you could mold it around the antenna for a seal. The candle showed that the LED could be molded to look like a flame as it was covered.
                  • 1937
                  #53
                  Scott T.
                  I understand what you are trying to do. Thank you your input. Another option I could use, but at this point I am not going with the 2.4 system on this boat.
                    • 2513
                    #54
                    We all have that, it's called the sun.
                      • 1937
                      #55
                      It has certainly been a while since I have been able to work on my HMS Stickleback submarine! But here I am back at it again.
ID:	182972 Click image for larger version
                      These photos show approximately where I left off on the build. I am ready to put the hull sections together for the upper hull, at which point I can start on the control surface installation and prop installation.
                        • 1937
                        #56
                        Today I finished up putting the upper hull sections together, and installing the WTC hold in place bracing as well as the bracket supports for holding the top deck down.
ID:	183005 Click image for larger version
ID:	183006 Click image for larger version
                        I will be installing threaded brass insert and using stanless steel bolts for holding the top deck in place.
                          • 1570
                          #57
                          Reminds me of Dave Merriman favorite movie, “Submarine X-1”’.
                            • 1937
                            #58
                            Today I went to work on the fasteners for the top deck hold downs.
ID:	183032 Click image for larger version
ID:	183034 Click image for larger version
                            I realize this sort of stuff is somewhat elementary to most of you guys, but it does show how I use the threaded brass inserts and stainless steel screws for my hold downs. The Vaseline that you see is used on the screw threads while using thin CA to secure the brass inserts, the Vaseline keeps the CA from penetrating the threads. I have also used the tip of a hot soldering iron to melt the brass inserts into the hole. Both ways work well.
                              • 1937
                              #59
                              After some breakaway time from the Stickleback building (The Shark Build) I am back on finishing up my Stickleback!
                              I have the WTC installed and locked into place, and both top deck hold downs completed I can now move onto the propulsion system and the control linkages. Along with the Stickleback submarine build, I latched onto another project that will be sort of back and forth. If you look down and the right hand corner of the photo you will see this new project.
                              This is going to be of some interest for Ken, and Bob G. They ​both enjoy building surface boats (Target Boats) to submariners! I will be doing a short build blog on this forum for the outboard motor as well as a surface boat which I will install the outboard on. (Just a fun breakaway project)
                                • 1937
                                #60
                                Today I took the old oil light prop bushing out and replaced it with the correct Dia. size. Now the prop is turning straight and true and no wobbling. And instead of a dog bone type hook up I was able to use a stainless-steel universal joint to tie the prop shaft to the motor shaft. Totally better!
Name:	STICKLE BACK 45.jpg
Name:	STICKLE BACK 46.jpg
                                I will now start on the rudder and the stern dive planes linkage.
