HMS X-Class Stickleback Midget Submarine
    • 2513
    The x-craft were essentially a smaller Holland class sub, with a simplified hull form to speed up construction, and some bow revisions for (slightly) better seakeeping on the surface. Like the Holland's, the skippers tended to trim them with a flooded or partly flooded rear tank when surfaced to get the stern low in the water, which is why photos of the boats in action tend to show them in a slanted trim when surfaced. Some modellers emulate this by incorporating a shiftable ballast trim e.g. move the main battery or suitable weight with a servo.
      • 3504
      1/22.5 scale X-51
      Internals
        • 1937
        These X-Class boats sure seem to be very popular among the submarine community!
        Tonight I finished up the lower hull sections, and I have started on the top hull sections.
        ​​​​​​​"Firemen can stand the heat."
          • 1937
          I built the HMS Holland. I have had it in the water only one time.
          Click image for larger version  Name:	HMS HOLLAND 154.jpg Views:	0 Size:	49.9 KB ID:	177336
          HMS Holland Trial Run (youtube.com)
          As you could tell, I have not achieved that low stern look yet. I am still working on it, and it still needs some addition paint work.
          Click image for larger version  Name:	SM UC 5 U-BOAT FINAL 6.jpg Views:	0 Size:	49.8 KB ID:	177337
          I also built the SM-UC 5 German sub. I have run it a couple of times, and it also needs some additional trim and paint work.
          I really have a passion for this type WW 1 WW 2 Boats.
          • DrSchmidt
            • Apr 2014
            • 1336
            SM UC 5 is a German minelayer, not a British sub. S.M. stands for "Seiner Majestät" -> His Majesties. So Imperial German Navy in WW I
              • 1937
              Thank You DrSchmidt,
              WOW! I stand corrected and appreciate you catching my error. I spent about 3 months building that boat and new full well it was a German Boat.
              Thank you again sir..
                • 1937
                I have started the printing process for the hull top sections of the Stickleback.
                The further I get into the build on this boat, the more I am impressed with the quality of the STL files.
                  • 3504
                  Bloody beautiful old boy.
                    • 1570
                    I wish you would finish the Seaview first.
                      • 1937
                      Casey,
                      I am working on the Seaview! My Flashforge is working right now printing out the parts for the command deck, and I am working on the hull putting it together as I write this post..
                      I always have two or three projects going at the sometimes> Just the way I like to do things. While I was printing out the parts for the Seaview I was building my life size fully functional Robot.
Name:	INMOOV ROB 150.jpg
                      One has got to keep busy and mentally involved at all times, or your dendrites fade away.
                        • 1570
                        Hey Rob, send that robot over here to mow my grass in the summer.
                          • 1937
                          Programing in the works!!
                            • 1937
                            Today I finished up the 3D printing of the upper and lower hull parts on the Stickleback.
                            Click image for larger version  Name:	STICKLEBACK 11.jpg Views:	0 Size:	58.9 KB ID:	177506
                            Click image for larger version  Name:	STICKLEBACK 12.jpg Views:	0 Size:	58.0 KB ID:	177507
                            Next will be to print out all the extra parts needed to complete the boat. So far I have been impressed by the quality of the prints.
                              • 1937
                              Tonight I finished the 3D printed accessories.
                              All the parts are completed and ready to be put together. I am very pleased how well the parts came out. My Dremel really does a great job printing small pieces.
                              • Alucard
                                • Aug 2023
                                • 105
                                #30
                                looking good, I like that if will be usable in your pool, that is something i have been thinking about also.
