3D Printed USOS Seaview project
    Casey,
    Looks like a perfect size for your desk area! Who makes the kit?
    "Firemen can stand the heat."
    Moebius kits.
      At this point I have all the hull sections printed out.
      I am going to start the actual glue up form the bow of the boat to the stern. There will be some light seam filling and sanding along the way, and I am going to do that as I put each section together..
        As I am building up the hull of the Seaview, I am also starting to print out the accessories.
        The photo above shows the beginning of the Command Deck parts. As I have stated at the beginning of this build, my Seaview is at 65% and not 100% size.
        As small as these parts are, I have got to say that my little FlashForge printer is doing an exceptionally great job at printing them. As good as or might be even better that a Resin printer could do! And with mush less hassle and mess, and not to mention the chemicals involved.
          This photo is for "Casey!"
          AS you can see I am making headway on the hull construction. test fitting parts to be sure they fit properly before you glue it up.
            It's about 1:30 AM in the morning, and I am working on the Seaview Command Deck.
            I have approximately 30 more parts to print out to finish up the command deck parts.
              Any monsters you could 3D?
                Casey,
                The only monster I have created right now is the Seaview! Still at a loss as to where I am going to find room for it when finished. I can always stand it up vertically, I guess?
                  • 13983
                  #68
                  Casey,
                  Come on, you old fart!... you were once a kid. We would hang our models off the ceiling.
                    Now that might work!
                    Click image for larger version  Name:	AAA.jpg Views:	0 Size:	54.1 KB ID:	177460 Click image for larger version  Name:	AAA 2.jpg Views:	0 Size:	42.2 KB ID:	177461 Click image for larger version  Name:	AAA 1.jpg Views:	0 Size:	47.4 KB ID:	177462
                    I remember running out of space for my Fire Fly, I wound up using PVC pipe in out master bedroom. Got da say, that didn't go over very well! :-((
                    I do have one area on the ceiling that might work?! When your working outside the box, I guess you need to look up sometimes.
                    Thanks David, for the suggestion.
                      • 13983
                      #70
                      What went wrong... you had to take down the bedroom ceiling mirror? Damnit, man! Get your priorities straight!
                      Ducking for cover
                        Ducking for cover
                        OH god, I better clear this up in a hurry before it really gets out of hand. It's not in the master bedroom (and certainly not the ceiling there) but the adjoining master bedroom closet/bathroom ceiling
                        "Firemen can stand the heat.".
                          • 13983
                          #72
                          Ah!... My bad.
                            Looking awesome, Rob. Even at 65%, she is still a beastly boat...
                              Ah!... My bad.
                              Just funning Dave,
                              Got have a good laugh sometimes for sure.. :-))
                                I got a wild hair and built a 1:350 Seaview this week. Only problem was getting the lenses on the fins. They were so tiny. Click image for larger version
