3D Printed USOS Seaview project
    I am using the STL files that I purchased from Nautilus Drydocks. It is a 1/72 scale model at a 100% (approximately 96" long.) I have reduced the files down to 65% which will give me a size of approximately 56" in total length, and a hull beam of at it's widest point of approximately 41/2". The 65% size will allow me to print this boat in my Dremel 3D40 DigiLab printer. I will be using Dremel white PLA, and printing at 100% infill.
    I will be posting progress photos and a written report as to the building progress as I proceed with this project.
    More to come!
    "Firemen can stand the heat."
    I knew coming in that I was going to have a few printing issues. One was going to be the wall thickness. The original STL files at 100% size has a 3mm thickness. I was very pleasantly surprised that at the 65% size that I am printing the walls came out to 2.20mm, which turns out to be great. Looking at the photo below.
    You see that I am dealing with some stringing, which again is no problem. I chose not to use any supports in this piece (which was my test piece) to not only save on filament (310' down to 134') and also bring the print time down from 23 hours to 12 hours. The little amount of time cleaning up the strings is worth the savings in time and materials.
    Other than that the overall piece looks great! I would say that the reduction in size for me is going to build into a really nice Seaview and the money spent on the files very much worthwhile for me!! :.)
    • Alucard
      • Aug 2023
      • 105
      Looks like a great start.
        • 3666
        That's great.
        Something for a 1/72 Skipjack to chase.
        • Alucard
          • Aug 2023
          • 105
          Right before the Seaview blows it up, lol.
            • 13940
            That's great.
            • Alucard
              • Aug 2023
              • 105
              Great pics for the post.
                Right on David!
                Those are some great photos you put up! And with your permission sir, I would like to copy some of them and use as some wall posters. Thanks David!
                  • 13940
                  Right on David!
                  I'm flattered, Rob. Have at it, sir.
                    Thanks David!
                    I have a few more photos of my Seaview build progress.
                    The photo above shows 3 new sections that I finished up yesterday. The first part that I built (Previous photo) with all the stringing from the printing, was just not satisfactory for me. I made the decision to build all future parts using any and all supports required. The extra filament and time that it takes to DO IT RIGHT are well worth.
                    The photo above shows the bow section parts starting to come together. One of the nice things I noticed about each part has the part name printed on the inside of each so that you know what the are. Nice touch. I am very pleased with hown the parts are coming together.
                      • 1629
                      More to come!
                      Keep us posted Rob.
                        • 1629
                        You read my mind, Dave. Those are really cool photos that I was hoping you could post.
                          • 1629
                          Good start Rob. Do they happen to have the eight window Seaview in files too?
                            [QUOTE=Das Boot;n176534]
                            You read my mind, Dave. Those are really cool photos that I was hoping you could post. [/QUOTE
                            Casey,
                            Those are some of the best photos of the Seaview that you will ever see that you can copy and print out. I am going to copy most of them and put them in frames. I did find some nice pictures on line, and I tried to print them out and they have copy right marks all over them.
                            Thanks again David..
                              • 1629
                              Rob, I’m so far behind on a 3-D printing, I don’t know if I’ll ever catch up. You have it down pat, buddy.
