Type XXI WTC
  • cgbillb
    • May 2018
    • 182
    Type XXI WTC
    Good day one and all
    I got my type XXI from Bob today it is a 1/72 scale boat. Here is my question, and I have gone thru most all the pages here with no results.
    1) What WTC should I use? I was thinking Bob's 250 series with dual shafts. With a ballast tank of about 8-10 inches.
    2) What would be the best way to install the WTC, I was thinking something like the Type XXIII found on David pages?
    Thanks for any help
    Bill
    Athens Ga.
    I watched Bob's video about the Type XXI he's selling. The hull is designed to split axially fore and aft. If you want a longitudinal hull separation either you cut the hull using a dremel or modify the file.
    • cgbillb
      • May 2018
      • 182
      I am thinking going the L-design like David did in his type XXIII
      Bill
      Athens Ga.
        The axial split is best suited for cylinders that have the equipment tray as one large section. With the traditional three-piece cylinders that we use here in the US, access from the top is much better. The XXI is actually very well. Suited to have a simple waterline cut across the entire boat. No need for L or Z cuts.
        • cgbillb
          • May 2018
          • 182
          wow thank you, Glad I have not cut the hull yet, Hope all is well up there
          Bill
          Athens Ga.
