Type XXI WTC
  • cgbillb
    • May 2018
    • 182
    Type XXI WTC
    Good day one and all
    I got my type XXI from Bob today it is a 1/72 scale boat. Here is my question, and I have gone thru most all the pages here with no results.
    1) What WTC should I use? I was thinking Bob's 250 series with dual shafts. With a ballast tank of about 8-10 inches.
    2) What would be the best way to install the WTC, I was thinking something like the Type XXIII found on David pages?
    Thanks for any help
    Bill
    Athens Ga.
    • 3664
    I watched Bob's video about the Type XXI he's selling. The hull is designed to split axially fore and aft. If you want a longitudinal hull separation either you cut the hull using a dremel or modify the file.
    • cgbillb
      • May 2018
      • 182
      I am thinking going the L-design like David did in his type XXIII
      Bill
      Athens Ga.
        • 2031
        The axial split is best suited for cylinders that have the equipment tray as one large section. With the traditional three-piece cylinders that we use here in the US, access from the top is much better. The XXI is actually very well. Suited to have a simple waterline cut across the entire boat. No need for L or Z cuts.
        • cgbillb
          • May 2018
          • 182
          wow thank you, Glad I have not cut the hull yet, Hope all is well up there
          Bill
          Athens Ga.
