Is there Anything that Epoxy Will Not stick to
  • george
    • Dec 2010
    • 731
    Hello
    I was wondering besides silicone molding, is there any material that can be used to create a form and then pour epoxy into or to it so that the material will hold the epoxy till it cures and then the material can be removed by hand without needed a power sander to remove the material from the epoxy?
    Thanks for your tips/help.
    George
    • 3390
    Learn everything about what Resin does not stick to ✔ Tips and Tricks for the best materials ✔ Make sure your Resin gets demolded ✔
      • Oct 2017
      • 892
      PP.
      Smooth pvc.
        • 2421
        Just apply four or five coats of a good non silicone wax, buffing between coats, will afford a good release from pretty much any material. You do have to be thorough though.
        • george
          • Dec 2010
          • 731
          Wow Thank You ALL for your replies here and for the link above. I did not know there were so many things that epoxy did not stick to.
          Thanks again for the tips.
          • DrSchmidt
            • Apr 2014
            • 1255
            Teflon.....epoxy will not stick to teflon
