British submarine id
ID:	75708Click image for larger version
Name:	HMS Aliance.jpg
ID:	75709Click image for larger version
Name:	HMS Spartan.jpg
ID:	75710Click image for larger version
      That last picture says Trafalgar. Im not so sure about that.:pop
      • Peter W
        • May 2011
        • 511
        #138
        Looks more like an Upholder. The beam looks too narrow and the rudder top is angled back, on the Trafalgar it is level.
        Best way to tell between Swiftsure and Trafalgar by the way is usually the height of the rudder, Trafalgar class are taller whereas the Swiftsure rudder is usually level with the after casing.
        Peter
          As I was posting it, what caught my eye was the amount of spray coming off the bow near the large sonar arrays. WAIT a minute. Only the "Upholders" had those (three per side) sonar arrays. So I figured it was a "U" class but was awaiting your observations, Dude.
          • Peter W
            • May 2011
            • 511
            #140
            Mark, flank arrays,yeah meant that too.BLUSHER especially when it was so obvious.
            Peter
            • unseen
              Banned
              • 39
              #141
              I think you will find that they are not sonar flank arrays. They are nothing more than casing service plates which could be easily removed, the flanks are well below the water line. I visited Unicorn at Lairds during her fitting out a few days after launch, where they had them removed.
              • herrmill
                • 360
                #142
                What Class This Be?
                Ok, RN sub fans tell me what class this is in the photo alongside RMS Aquitania taken 1919-20. I can't place it but then I'm too lazy to
                dig out my copy of Sutton's HM Submarines in Camera. Could it be one of the last of the L class?
                Aquitania at Armstrong Whitworth & Co. Newcastle-on-Tyne, England for her post war refit.
                Note the new bridge has already been constructed and the two submarines under construction alongside.
                • Roddersuk
                  • Sep 2011
                  • 56
                  #143
                  Greenman, please can you apply the correct adjective in your writings. Their is an adjective and refers to of or belonging to them. In most cases you use the adverb There, which is in or at that place. Submarines and ships are female so therefore should be described with the adjective Their. For example, There is a submarine. Their accommodation / armament was upgraded on refit.
                    One of my favorite peeves! Good work Roddursuk! You've been enlisted into the Grammar Police!:biggrin:
                    • roedj
                      • 564
                      #145
                      You're moving to the fore in saying, that I too have observed that, unlike in the days of yore, they're moving their four subs there to your naval base for two navel oranges.
                      (I would've also done seamen and semen but this is a family forum).
                      Oberleutnant Dan
                      Grammar Gestapo
                        • 13982
                        #146
                        (is it a full-moon?)
                          Thank you Roddersuk, Ill try to keep that in mind. I need lots of reminders.
                          • unseen
                            Banned
                            • 39
                            #148
                            [ATTACH=CONFIG]18322[/ATTACH]
                            Well if your dates are correct the only two boats which appear to be under contruction during that time at Whitworths were K20 and K21. These boats did not complete as K Class but were converted into monitor submarines M3 and M4. No doubt someone will have a more informative explanation. However, a poor photograph for identification purposes
                              TALLY HO!! Stand by for action!
                                Ok you Stately Gents..............(uhhum, cough , cough). Here we go with a wee bit o jpegs, with a slightly British flavor, hope you blokes dont mind. Its been a while since I padded the stern of this thread.
Name:	Brit sub 1940.jpg
ID:	81625Click image for larger version
Name:	Pandora or Parthian.jpg
ID:	81626Click image for larger version
Name:	Pandora or Parthian and surcouf side.jpg
ID:	81627Click image for larger version
Name:	Pandora or Parthian from Surcouf.jpg
ID:	81628Click image for larger version
ID:	81629Click image for larger version
Name:	U class zoom.jpg
ID:	81630Click image for larger version
Name:	Vanguard rear quarter.jpg
ID:	81631Click image for larger version
ID:	81632Click image for larger version
Name:	Vanguard side zoom.jpg
ID:	81633Click image for larger version
Name:	Vanguard behind sail.jpg
