HMS Holland 1 - 3D CAD model in the making
    • 2582
    #76
    I beleive the periscopes on the four boats were all slightly different, certainly differences between Holland 1 and Holland 5, the latter I believe got the first one.
    Here's an image of Holland 1 periscope base.
    • DrSchmidt
      • Apr 2014
      • 1374
      #77
      That's an awesome foto which would have saved me quite some time. So I might redo the cowling again....that's my current version:
        • 2582
        #78
        Got it from this website
        • DrSchmidt
          • Apr 2014
          • 1374
          #79
          Closer....
            • 2582
            #80
            Here is a side shot of Holland 5. Unfortunately this boat is now on the sea bed covered in marine growth, so not the greatest for reference. The Rn submarine museum in Gosport may be able to give you some additional reference.
            • DrSchmidt
              • Apr 2014
              • 1374
              #81
              I British gentleman shared his research material about the Holland 1 with me and I got plenty of photos of the current Holland 1 at Gosport. Unfortunately they didn't cover the periscope dome in good detail. But that issue is fixed now due to your help. Thanks for that....
              I found another photo that is a riddle to me....
              It shows Holland 1 with a restored interior. That's definitely not the current status of the boat and I couldn't find any additional info. So I'm wondering if they tried to restore ist and had to undo all of it again because of preservation purposes. The long time in the salt water didn't do the metal no good.
                • 2582
                #82
                It was like that when I visited the Gosport museum about fifteen years ago.
                A lot of the corrosion happened after it was removed from the sea bed, as the boat was kept outside. After a few years it became evident the boat was at risk of dissolving into rust unless something was done, and subsequently the boat was encased in a sealed pod and treated to remove all salts out of the steel. It stayed that way for several years before it was removed and located in a custom built building with humidity carefully controlled.
                The Hollands were built from a higher grade of steel than other vessels of the day called s-grade. This may be a factor in their longevity on the sea bed.
                • DrSchmidt
                  • Apr 2014
                  • 1374
                  #83
                  Some mor details about the interior of the periscope installations....
                  • DrSchmidt
                    • Apr 2014
                    • 1374
                    #84
                    I added the support structure for the periscope actuator and in the back the hand wheel to drive the rear dive planes....
                    • DrSchmidt
                      • Apr 2014
                      • 1374
                      #85
                      After the depth control I'm working on the rudder controls. The Holland could bee steered from three positions: deck, conning tower and a seated position under the periscope. Every position had it' own steering wheel, and all those wheels were connected via a central gear box to the drive train to the stern....the central position under the conning tower with the gear box is almost done.
                        • 3724
                        #86
                        I am learning a lot from your 3D designs. I do wish you would work with Bob and allow us to purchase a set of stl from you. Even with the caveat that the ability to print cannot be guaranteed. Thank you for documenting your efforts.
                        • DrSchmidt
                          • Apr 2014
                          • 1374
                          #87
                          Thanks!!!
                          Progress on the rudder controls: on the left of the central wheel is the gear that connects the controls to the drive shaft that runs all the way back to the stern where the rotation is translated into rudder tilt.
                          • DrSchmidt
                            • Apr 2014
                            • 1374
                            #88
                            And with the right gear, that connected the steering position for suberged cruise with th rest of the rudder actuators. Not really fly by wire...
                            • DrSchmidt
                              • Apr 2014
                              • 1374
                              #89
                              Still working on the drives for the control planes. I finished the outboard feedthrough for the rudder. Outboards there was a stuffing box surrounded by a frame holding the bearing for the worm gear driven rudder lever axis. The worm gear was positioned by a metal box, that was bolted to one of the circular frames.
                                • 13890
                                #90
                                Damn!... just, DAMN!!!
                                Doctor: You are a crazy man! What a study!
