Differential thrust with a 75 MHz radio?
If need be, I'll spoon-feed you during the process. And here's the nice part: 2.4gHz receivers are so dirt cheap now you can use them as training aids! The antenna swap to a length of coax is not as hard a task as you suppose.
DavidWho is John Galt?👍 1Comment
Make it simple, make strong, make it work!Comment
I also like the fact that it is only one ESC, saves space in the cramped SD.Comment
Last edited by redboat219; 10-05-2022, 10:31 AM.Make it simple, make strong, make it work!👍 1Comment
And thanks to all who chimed in here. This was truly helpful and moves my project along.Comment
Received them this weekend: Oddly enough they sell them in a pack of three. Of the three one worked for about a minute. Didn't die but after I turned it off and on again, it was as dead as the other two. All three don't initialize on power up. No idea why. Bummer.Comment
