Differential thrust with a 75 MHz radio?
  • tifosi12
    • Jul 2020
    • 418
    If a club-footed, fat-handed, cross-eye'd creature such as I can solder without bridging closely spaced PCB pads, then so can you!! Use a 15-Watt iron with a pointed tip and you're golden.
    Ok, I'll give that a shot too. About time to get a new soldering iron anyway. And since I bought a 2.4 GHz transmitter and Rx recently, I might as well try it. Got nothing to lose at this point.
      • 13668
      Good man!
      If need be, I'll spoon-feed you during the process. And here's the nice part: 2.4gHz receivers are so dirt cheap now you can use them as training aids! The antenna swap to a length of coax is not as hard a task as you suppose.
        • 821
        Many newer 2.4 Rx's use an ipx connector for the antenna(s). In that case, no soldering required but you would need a length of cable with the connector on it.
          • 3493
          I don't think that would work as that would make both motors go at the same speed.
          The yellow lead plugs into the rudder channel so you have differential control over the motors. If you don't connect it both motors will run synchronously.
          • tifosi12
            • Jul 2020
            • 418
            Oh wow, that's nifty! Got a source/link for that ESC?
            I also like the fact that it is only one ESC, saves space in the cramped SD.
              • 3493
              https://www.amazon.com/gp/aw/d/B0B4N...G9uZV9kZXRhaWw
              • tifosi12
                • Jul 2020
                • 418
                Thanks much!
                And thanks to all who chimed in here. This was truly helpful and moves my project along.
                • tifosi12
                  • Jul 2020
                  • 418
                  You guys showed me several paths to a solution. I'm going to pursue all of them. Getting this solved is crucial for my next two projects so thank you very much to all of you. Great community!
                  • tifosi12
                    • Jul 2020
                    • 418
                    How about a dual motor ESC?Click image for larger version
                    Received them this weekend: Oddly enough they sell them in a pack of three. Of the three one worked for about a minute. Didn't die but after I turned it off and on again, it was as dead as the other two. All three don't initialize on power up. No idea why. Bummer.
                    • tifosi12
                      • Jul 2020
                      • 418
                      Swapped the Rx for another one and now magically it works! Yeah!
