Hms holland 1 build
  • jphatton
    • Jan 2021
    • 112
    #121
    A general arrangement plan of Holland 1-5 is in the online copy of BR3034 publication on early British submarines in plate 1;
    Also John Lamberts plan which appears to be based on the above general arrangement drawing is included in the Holland 5 wreck divers guide leaflet. The embedded plan in the PDF is reasonably high resolution if you enlarge the view of the PDF file.
    • DrSchmidt
      • Apr 2014
      • 1393
      #122
      Thanks allot. I already found the PDF and started importing it into my CAD program. Could work....
      • gantu
        • 428
        #123
        Hi i do have a 3d file.
        Regards Gantu
          Does actually someone have good plans of the HMS Holland? Would be a nice little "cut away" display project.....
          Andreas,
          In all my travels through the internet about the HMS Holland I have not seen any7 "cut aways" of the Holland. I have not been to Thinaverse or CGtrader. I got my STL files for my Holland build from CGtrader, but I did not notice any "cut aways"!
          I will start doing some more research and see if I might find one. I got to say with your wonderful skills as a modeler, the HMS Holland would be a show case model for sure!!
          • DrSchmidt
            • Apr 2014
            • 1393
            #125
            Thanks allt, but I don't need a 3D mdel. That I can do myself. I'm just looking fr god 2D plans.....
              Sorry Andreas, I misunderstood what you said, but I will look around and try to find 2D plans...
                As I stated before after I had my first run in the water, I may be enlarging the upper and lower rudder!
Name:	HMS HOLLAND 133.jpg
                I 3D printed two new larger rudders and I did have to cut off a little excess so they would fit. No problem!
Name:	HMS HOLLAND 132.jpg
                The old rudder is on the right in the photo. The two new rudders are 5/16" wider than the old ones.
                I think this new rudder system will give me much better turning ability in my pool! :-))
                • DrSchmidt
                  • Apr 2014
                  • 1393
                  #128
                  Working....
                    Andreas,
                    The photo of 2D plan of the HMS Holland 1 looks like it could work for you for your upcoming 3D model build! If you decide to build the model, I hope that you do a build blog. I for one would be looking forward to it. You are the master at this concept, and the HMS Holland 1 is such a distinctive looking boat! Thanks for posting up the photo! :-))
                      The HMS Holland 1 build is complete! The hull with all the accessories, and the WTC complete and functioning!
Name:	HMS HOLLAND 134.jpg
                      Next comes the finishing work. I will be using an auto body grey primer 2 coats with sanding between coats and then the final hull colors, and then the final touch up finishing on the accessories!
                        • 825
                        #131
                        Looks really good Rob.
                          Thank you, Steve,
                          Ita has been one of the most challenging boats I have ever built! But it has been the best performing boat in the swimming pool! With the enlarged rudder I can now do a full 360 turn in my pool, and that makes it a joy to run.
                          Ounce I have all the finish work is completed; I will be sure to have my wife take a video of it running all out in the pool!
                            The HMS Holland 1 is nearing completion!
Name:	HMS HOLLAND 141.jpg
ID:	166032Click image for larger version
Name:	HMS HOLLAND 140.jpg
Name:	HMS HOLLAND 139.jpg
ID:	166035Click image for larger version
Name:	HMS HOLLAND 137.jpg
Name:	HMS HOLLAND 136.jpg
ID:	166037Click image for larger version
Name:	HMS HOLLAND 135.jpg
                            The interior of the boat is sealed, and the exterior has two coats of primer and has been sanded in-between each coat! I still have not come up with what my final hull colors will be from the three that I have in mind. This boat is very near total completion, and now I can put all my time on the SM UC 5 U-Boat build.
                            I am also going to put my printer to work on another boat, just not sure which one yet!
                              This will be my final selection for the Holland 1 as to color and design.
Name:	HMS HOLLAN 140.jpg
                                Here is even a little better photo of the color scheme that I will go with!
Name:	HMS HOLLAND 149.jpg
                                "Firemen can stand the heat""
