torpedo system
I will be watching this thread. you have my complete attention.
Jim:)Put your mind to it. If there's a will there's a way!Comment
Rick L.
Since Learning is Always a 'Good Thing' *Comment
David,Who is John Galt?Comment
ok i will think of ideas also. the magnet part to swtich off and on im sure is they way to go . But i will think of some other ideas also.
JimPut your mind to it. If there's a will there's a way!Comment
Yes, I know I have some small reed-switches (the type sealed in glass tube), if I can find them.
My stack of Goody-boxes is Very Large, after about 50 years of scrounging and collecting, and those switches are Very Small! :D LOL :DLast edited by toppack; 01-02-2009, 12:39 PM.Rick L.
Another problem is that since the very small motors (without gearing) have High RPM but not much Torque, so the motor has trouble overcoming the drag of the shaft seal along with the force needed to turn the prop. Need a shaft seal that is water-tight but allows shaft to turn freely at high RPM.
I think some kinda tubing would make best seal, maybe teflon tubing, if I can find shaft rods and tubing the correct size to make a watertight fit.
I got some more small motors, (direct from HongKong), that are only .24" diameter, but problem with them is that motor's shaft is only .030" dia. and about .1" long, which is not much for a tubing type shaft-coupling to grab onto.
They operate well at 1.2 volts and really scream at 2.4 volts. :)
I found that motors I removed from servos don't operate well at 1.2 volts.
They like at least 3. volts, which may be okay if I have to use and stack button type batteries, since I'll have enough length space to stack a bunch of them (probably 4). (Button type like used in hearing-aids)Last edited by toppack; 01-02-2009, 06:08 PM.Rick L.
this looks like an ideal motor for the torpedos, im looking for some tubing that i may be able to find with threaded ends i know some one that works with plastics that may be able to help out. this way the torpedo, can be un screwed into two pieces. But i like the one thats on youtube were he has made his from scratch displaying it in the bathtub, running it for the first time. I have written him for were he has gotten his supplies but no responce so far.Put your mind to it. If there's a will there's a way!Comment
It would be best to make both ends from somthing that floats (one that prop-shaft goes thru & one nose).
Yes, a good way to attach those end pieces correctly, to center tube, is a Critical and maybe difficult part of the assembly.
I've not thought about that part of it much yet.
Want to find some tube that is thin walled, not magnetic, but easy to attach.
Since it needs to be thin-walled, I doubt it could have Threads?
Maybe just a press fit with a O-ring seal, and a locking pin if necessary (if there's a small internal spring to keep a battery stack tightly together, pushing against nose piece)?
Remember we're talking about something about the size of a fountain-pen! :)Last edited by toppack; 01-03-2009, 07:18 PM.Rick L.
yes thats true a fountain pen, i will see what thin wall plastic tubbing i can find and keep you updated with a picture. Meanwhile i think you are right with using a o ring simple also. battery will have to be those hearing aid batterys. Can't think of anything else to generate enough power.Put your mind to it. If there's a will there's a way!Comment
Good idea David, i know a place that makes carbon fiber tubing. I will see what they have in stock. I think they make special orders so if they do i will find out how much for the tubing. I need to have a idea what's the maximum length of tube it should be and tube diameter, that would be perfect for such a project. If this works i will mail the tubing to you that are interested so we all can build one of these torpedos for testing.
Oh' by the way what about having compressed gas coming out of a small hole at the end of the torpedo, for propulsion, that sounds real simple any idea's about this.
JimLast edited by deepseadiver; 01-05-2009, 01:10 PM.Put your mind to it. If there's a will there's a way!Comment
