torpedo system
  • toppack
    • Nov 2008
    • 1124
    #181
    Yes, We will see.
    I'll try fo find those videos of working torpedos again.
    Rick L.
      #182
      Rick what subs are you running?
      • toppack
        • Nov 2008
        • 1124
        #183
        The Revell Gato is the one I've completed.
        I also have Revell U-boat and the fiberglass T-class in the works.
        Most of my RC ship model building experience is with surface ships, 17 operational, and I'm really enjoying learning about subs. :)
        Rick L.
          #184
          well I am sure David will confirm it, but his system I think should fit the Revell Gato.
            • 13981
            #185
            Originally posted by toppack
            I really appreciate the suggestions, But I've seen battery powered, single-prop, torpedos that work and operate the way I want mine to. So I know it can be done.
            Now wheather I'll be able to construct them with one good hand is another concern but i want to try for several reasons. The biggest ones being that I like to create my own designs and fabricate them and the other being that I know I'll not be able to afford David's creation, since he's going to be very proud of it, and rightfully so. :D LOL
            Thanks,
            Substitute the battery with an electrolytic capacitor and you're home free.
              #186
              God he's good. :)
              By doing so - you can not worry about a kill switch as the full discharge can be dumped into the motor - so the torp just stops when its out of fuel. Just need to figure out which electrolytic cap would suit the motor and desired torque for best effect.
              The weight issue - gone too.
              You just need to:
              -counter the torque roll
              -build a release mechanism (you could use a reed switch thats NO and trigger switch / circuit closure and motor start via rare earth magnet on a push rod that comes along side the torpedo near the reed switch).
              -work on a charging mechanism
              David is there nothing you don't know.:D
                • 13981
                #187
                I know that I better give credit where credit is due: Dan Kachur, out of Canada, one of the best builders and operators in this game today. He's done effects work for the Canadian film industry (X-files is one credit he has).
                He perfected the electrolytic torpedo years ago and they have all the attributes you observed, John.
                He sent me a video of his torpedoes -- fantastic work!
                  #188
                  Have just seen in the mall here an application that might be worth studying Rick
                  Those tiny IR helicopters run on these caps.
                  The IR TX doubles as a charge station for the helicopter
                  The helicpoters feature tiny motors (similar to what you have posted)
                  The helicopters have counter rotating blades....
                  So there is the ingredients of what I would study to take the electric warshot further.
                  Now David how about those pain in the butt questions mate?
                    • 2640
                    #189
                    I think you'll find the little helicopters use small single cell li-po's- the ones I have do.
                    You can use an ultra capacitor for power, these are more widespread now, and under constant development- they're looking to fit them to electric cars.
                      #190
                      Andy,
                      thanks for this.......any ideas for what cap would be useful for a scale warshot or around say 1/72?
                      I'm still going gas with David - but I'd still like to know.
                        • 2640
                        #191
                        You have something like this-
                        However, they would only suit larger scale torpedos.
                        There are some truly tiny Li-pos available nowadays with impressive amounts of charge, and I would look at those. I reckon you could get down to 1/72nd scale with an electric torpedo, 1/96 scale would be difficult.
                        You could switch them on and off using reed switches and an electro magnet via a small microcontroller feeding a MOSFET to the little motor. the same microcontroller can be programmed to feed the motor for a specified time (say 5 seconds).
                        This stuff is so small it could all be mounted inside the torpedo. The electromagnet would be mounted inside the submarine and switched via a spare channel.
                        • toppack
                          • Nov 2008
                          • 1124
                          #192
                          Yes, I experimented with capacitor powered torpedo motors. This was discussed before in this thread, I think.
                          I found that they would have an even shorter propulsion range than gas does.
                          Not what I want!
                          Rick L.
                            • 2640
                            #193
                            What amount of capacitance were you running, and what were the size of the torpedos and motors powering them?
                            For a small torpedo you should be able to get at least 30 seconds of running (how much range do you want!).
                            • toppack
                              • Nov 2008
                              • 1124
                              #194
                              As stated earlier in this thread, I want to be able to launch from middle of pond to shore, at least several times before having to recharge Anything. :) A 3A battery, on these motors, should be able to do that and then some. I don't want to have to retrieve any from middle of pond. I want them to land at my feet, ready to go again. :)
                              As stated earlier in this thread, I'm making a tray with built in deactivation magnets in it, to turn off motors as they are retrieved on shore, to be ready to reload.
                              Rick L.
                                • 2640
                                #195
                                Yes, okay, but my response was chiefly directed towards John's request for a system small enough for a 1/72 fish.
                                Here's another link to some suitable caps http://media.digikey.com/pdf/Data%20...Z%20Series.pdf
