Ordered A New Boat
    Ordered A New Boat
    I just found and ordered the last Bronco (edited) Type XXIII on Amazon. Maybe one day I’ll find a WTC for it. Guess I’ll put it on a shelf until then.
    Click image for larger version  Name:	DE94D6D6-AA43-4CD5-A965-4DD4A95BDFEB.jpeg Views:	0 Size:	72.1 KB ID:	155352 Thanks. I meant Bronco. I’m an idiot.
    • DrSchmidt
      • Apr 2014
      • 1393
      There are actually RC conversion kits available for this boat......
        How about Bob's 2.5" MSD?
        • jphatton
          • Jan 2021
          • 112
          There are a couple of dedicated Type XXIII conversion kits that I'm aware of. Maximus Modellbau in German has new version of the conversion kit with a 70mm WTC which uses a peristalic pump and bag type ballast tank. R&R Engineering in the UK also has a new 70mm with a pumped tank (snorkel) and provision to use the forward planes of the model.
            The 2.5" MSD is out of production. I will have a new 3" SubDriver released in the next week or so. I've also hooked up with Ron Perrot to offer his 70 and 80mm units while my own is under development. Those should be arriving in the coming weeks once he fulfills my stocking order.
              • 2642
              They're very well regarded here in the UK.
              Have you considered stocking the Aquabat? Pretty decent starter boat and a good fun boat for the more experienced.
                It looks like Maximus Modellbau uses a bayonet ring system which I would love to try. It would save cutting the top off with a dremel.
                  • 13988
                  Originally posted by Das Boot
                  It looks like Maximus Modellbau uses a ring system which I would love to try. It would save cutting the top off with a dremel.
                  (pussy!)
                  • Monahan Steam Models
                    • 755
                    You still have to make a new cut in the hull with the Maximus Modellbau system. It would’ve been better if the system was designed to use the existing hull split. Also it the system provides no separate control option for the forward planes. The system is also designed to control the rudder with external linkage. That’s cheating.
                    The “dreaded” long horizontal cut is the all around better way to go. Just my two cents.
                      (pussy!)
                      Yes. I ruined a Seaview trying that once. Not again.
                        • 13988
                        YEAH... Casey. What he said!
ID:	155394Click image for larger version
ID:	155395Click image for larger version
ID:	155396Click image for larger version
ID:	155397Click image for larger version
ID:	155398Click image for larger version
ID:	155399Click image for larger version
                          Looks like a Medieval torture device.
                            My first sub, the 32nd Parallel Type XXIII, used an external linkage for the rudder. I can’t remember if the rear dive planes were even hooked up.
                              Check out this video. The gentleman used the factory break in the hull with a slight mod.https://youtu.be/dwpT6FzhrZI
