RC Conversion of Trumpeter 1/144 Submarines
    All knowing HWSNBN
    I want to know if you're planning or currently doing RC conversions of the Trumpeter 1/144 JMSDF Soryu class, HMS Astute or their newly released Chinese PLAN Type 094 Xia class SSBN.
    Some pictures of the Xia kit showing the separate stern planes as opposed to the fixed ones on the Soryu and Astute.
    S Click image for larger version
ID:	152391Click image for larger version
ID:	152392Click image for larger version
ID:	152393Click image for larger version
ID:	152394Click image for larger version
ID:	152395Click image for larger version
ID:	152396Click image for larger version
    • 14014
    All knowing HWSNBN
    I guess the word has not gotten out, but earlier this year I 'retired' from the commercial end of the r/c model submarine trade. I no longer produce product for commercial sales. I plan to spend the rest of my misserable life addressing my bucket-list, most of that comprising unfinished model submarines currently residing on my shop walls. I'm now exclusively in it for the fun.
    But, as any attentive reader of this forum will know, I continue contributing to this and other sites, sharing my wisdome, smarts, god-like abilities, charm, and good looks for all those within ear and eye-shot. That will continue till I'm worm-dirt.
    So, no. I'm not going to produce conversion kits for anyone but myself. So there! However with future and past posts to the forums I have/will show you how to cram an effective r/c system into these small 1/144 scale model kits that continue to pop up for sale.
    Here are some shots of work I've done with a 1.25" SD I developed for these small critters:
    Now, you can do me a favor: Where can I find the above three kits you mentioned. I want them! And I want them NOW!
    And always remember... https://youtu.be/TlXHCykk7fU
    The Horrible.
      The 1.25 subdriver would be perfect for the Merit 1/35 British X-craft.
      What's the length of those SDs again? Click image for larger version  Name:	Screenshot_20210710-153710_YouTube.jpg Views:	0 Size:	74.7 KB ID:	152403
        • 14014
        Already working that kit up with an SD. Length varies with the job.
          How do you access the SD on yours?
          The X craft hull is molded in right ( with deck attached) and left halves. Was thinking of gluing the 2 halve together then make a vertical cut at the stern cone where the hull transitions. The fore and aft sections will be held together using rare earth magnets like what Manfred did with his Type XXIII. Click image for larger version
Name:	images (22) (2).jpeg
            • 14014
            Glue the two halves as you described. But, make the longitudinal (equatorial) side cuts at the maximum hull diameter. Vertical (radial) cuts near the bow and stern. Stern radial cut on the top. Bow radial cut on the bottom.
              Aah the dreaded longitudinal cut! Click image for larger version
                • 14014
                Now, now!... Stop whining. Credit where credit is do. I blame those two Canadians, Dan Kachur and Greg Sharpe for coming up with and promoting the infamous Z-cut towards the end of the last century. No better way to access the innards and still hide most of the inevitable gaps.
                • Monahan Steam Models
                  • 755
                  Has anyone here had good clean results making a longitudinal cut with a razor saw? Asking for a friend…..
                    Waterline ship models have become popular in larger scales, but, for a long time, kits with a waterline option typically came in 1/700 scale or smaller. Many of us have larger-scale ships in our stashes that don’t offer the waterline display, which means cutting the hull: a daunting prospect to be sure. However, it doesn’t have to be. Using a methodical approach and tools every modeler should have, anyone can convert a full-hull ship model for waterline display.
                      Merit molded the outlets for the external control linkages open. Click image for larger version
ID:	152435Click image for larger version
                        One flaw with the kit is the propeller, looks more appropriate on a plane. Click image for larger version
                        • wlambing
                          • Nov 2020
                          • 402
                          I make cuts with either a razor saw or an Xacto blade used backwards as a gouge. Works great in styrene! I try to line the cuts up to the underside of a molded weld line, at or below the waterline. Does 2 things; a) Makes a natural guide for a pretty straight cut, and, b) Hides the seam under the slight lip of the weld line. The fingers DO get tired, though!
                            David, regarding your personal conversion of the x-craft, are you fabricating new resin appendages or are the kit parts sufficient?
                              • 14014
                              All kit parts, even the propeller. As I no longer mass-produce it's a much simpler and quicker thing if I just adapt existing static parts to become dynamic parts. And this particular kit is most adaptable for conversion to four channel r/c use. Stern planes, rudder, ballast sub-system, and throttle. Eazy-Peizi.
