Repair of old D&E 1:96 Skipjack
  • spankey
    • Aug 2010
    • 103
    All,
    I've got an old (probably over 20 years old) D&E 1:96 Skipjack, and in the course of a move, it sustained some battle damage.
    I needed some advice on what to use to put it back together. The tail section is slightly warped (out of round), as are both the top and bottom. The sub had broken free of it's mountings in its transport box, and unbeknownst to me, had rested there for several years. I've attempted to wrap it in a bunch of rubber bands around the tail section to pull it back into round, but no dice. I'm almost wondering if I need to rebuild the entire stern....
    Any thoughts on how I can bend these things back into shape?
    Also, I'm hunting for a brass prop for the sub, since you can see I've got an opposite turning 7 bladed screw on it now (It was all I had to keep it running at the time).
    Thanks very much-
    DS-
  • 598602G
    • Jan 2017
    • 500
    Use a heat gun and heat up area that is twisted and twist it back into shape.
    • spankey
      • Aug 2010
      • 103
      Gotcha. How about adhesive to re-connect the tail feathers? I am hesitating to use CA.
        • 2759
        Best consult the maker, lol.
          • 12332
          Originally posted by spankey
          All,
          Thanks very much-
          DS-
          Wait for a bright, sunny, hot day. Remove the sail. Place the upper and lower hull halves on a table under the sun and take a nap. GRP has a bit of shape-memory. See if that pulls things back into round. Heat-gun is an option but fraught with risk!
          CA the stern cone back in place but insure that the propeller shaft is in perfect alignment with the hulls longitudinal centerline before you commit. Or use a slow-set epoxy adhesive. In either case use temporary brass straps to hold the unit in place to the lower hull till the glue changes state.
ID:	150845Click image for larger version
ID:	150846Click image for larger version
ID:	150847Click image for larger version
ID:	150848Click image for larger version
ID:	150849Click image for larger version
ID:	150850Click image for larger version
ID:	150851Click image for larger version
ID:	150852Click image for larger version
ID:	150853Click image for larger version
          • spankey
            • Aug 2010
            • 103
            Thanks alot. Right now temps are going to get pretty hot, so I'll leave it out for an hour or two to see if it'll relax back into shape.
            I'll also follow your advice on the stern cone and use brass strips to ensure alignment.
            If I wanted to put a (close to scale) brass prop onto this boat, does anyone know which of the Raboesch props would do the trick?
            Thanks all-
              • 1777
              Got them in stock.
              Skipjack 1:72 scale: 55mm diameter, Right turning, 5 blade, M4 threads:
              • spankey
                • Aug 2010
                • 103
                Sorry, I should have clarified, this is a 1:96 scale.
                But, given that diameter for the 1:72 scale, a 1:96 scale prop should be between 40-42mm. Does my math check out?
                Do you have any of those around?
                  • 1777
                  Hmm.. I don't think so, but I can have Jason check. I'm out of the shop now until August.
                  Actually, better yet, if you could reach out him directly at jason@nautilusdrydocks.com, it will cut out the middle man!
                  • spankey
                    • Aug 2010
                    • 103
                    Will do. Thanks Bob!
                      • 12332
                      Thanks all-
                      Screw that! Send me your address and I'll blast the proper propeller your way -- it's white-metal... deal with it!
                      • spankey
                        • Aug 2010
                        • 103
                        Darn-it! They're throttling your private message limits! Who's in charge here!?
                          • 12332
                          No. I let it max-out -- got tired of hearing all the *****ing, moaning, and vaginal distress you guys whine about. Contact me here:
                          dmeriman@aol.com
                          People want to talk to me? Use the forum. That way my greatness and charity can be seen by all.
                          • spankey
                            • Aug 2010
                            • 103
                            Love it. Email incoming. Thanks-
                              • 1161
                              You need to remember that Merriman is a sub God. Bow at his wisdom.
                              Of the 40,000 men who served on German submarines, 30,000 never returned.”
