Recent uboat pictures
    • 1639
    #301
    On the other hand, i've dugged up this drawing, there seems to be a pressure tight hatch present between the dome compartment and the pressurehull, i think they only used the dome during trails at shallow depths or running at the surface, going deep means shut the hatch and do a prayer that it won't crack.
      • 13937
      #302
      Good German engineering dictates two-valve protection (dome and trunk hatch) of the main spaces within. There appears to be a contoured seat where the 'observer' would plant his fanny when, ah, observing.
      Man! What a view! I would have killed to get that gig. But that location is just asking for a dead-head or the like to take out the Perspex dome. Hence, the trunk hatch. Maybe that's why they went for the cutter style stem in the superstructure seen in some shots of the V80. Good stuff, Manfred!
      I always wanted to look through a raised scope on the ascent to periscope depth, but the conn gets to be a busy place when getting within keel range of overhead traffic, so it never happened. Actual eye-ball observation from a combatant submarine through a submerged periscope head remains (until the Optronic type masts, anyway) the preview of ship control and intell guys doing scary things in the dark.
        • 1639
        #303
        David, that cutter stile thingy was used to split the waves when running at high speed at the surface, just like my model there is a tendency to dive nosedown when the waves went to far over the bow.
        They solved this by placing a wave cutter, which allows bigger speeds at the surface, that seat seems to be placed too low, my initial thought is, that the observer could stand on it, and the view would certainly be interesting.
Name:	WW1 German U boat.jpg
ID:	75224Click image for larger version
Name:	Unknown uboat.jpg
ID:	75225Click image for larger version
ID:	75226Click image for larger version
Name:	U-Boot-Bruecke- rear deck wintergarten.jpg
ID:	75227Click image for larger version
ID:	75228Click image for larger version
Name:	uboats in 1940.jpg
ID:	75229Click image for larger version
ID:	75230Click image for larger version
ID:	75231Click image for larger version
ID:	75232Click image for larger version
Name:	U995 closer.jpg
ID:	75233Click image for larger version
Name:	U776 first U boat to surrender.jpg
ID:	75234Click image for larger version
ID:	75235Click image for larger version
ID:	75236Click image for larger version
Name:	U408 and crew.jpg
ID:	75237Click image for larger version
ID:	75238Click image for larger version
            • 1639
            #305
ID:	75246Click image for larger version
Name:	Type 7 and U tanker.jpg
ID:	75247Click image for larger version
ID:	75248Click image for larger version
Name:	U31 prop-001.jpg
ID:	75249Click image for larger version
ID:	75250Click image for larger version
ID:	75251Click image for larger version
ID:	75252Click image for larger version
ID:	75253Click image for larger version
Name:	U66 docking.jpg
ID:	75254Click image for larger version
ID:	75255Click image for larger version
ID:	75256Click image for larger version
ID:	75257Click image for larger version
ID:	75258Click image for larger version
Name:	U190 or U290 mosquito damage.jpg
ID:	75259Click image for larger version
Name:	U210 as viewed just before destruction by destroyer.jpg
ID:	75260Click image for larger version
Name:	U534 depth charge damage-001.jpg
                • 1639
                #307
                All those pictures are from my private collection and made in the early 80's, at this stage they didn't messed up the boat that much due to 'restaurations efforts'.
                  Manfred, I like the way the zwitone pictures of 995 make them look like they were taken during the war years. The picture of the model u 552 with the bicycle almost looks real. Is that your model?
                    • 1639
                    #309
                    Von Hilde,
                    I think the sepia colour look came from my camera settings, i had to take pictures from pictures, i agree it gives a pretty wartime look, that modelpicture is not my type VII, i own a type VIIC instead of a B type, mine is also equipped with the complete array of flakguns and extended Wintergarden.
                      I only have a couple for today. I included a couple of the Visekko because it is in design, the first German Uboat of WW2.Click image for larger version
ID:	75354Click image for larger version
Name:	Vessiko lower bow.jpg
ID:	75355Click image for larger version
Name:	Vessiko stern.jpg
                        I think the Vessiko is a beautiful represintation of the type II. It looks like they should have to do some corrosion control soon. The pictures I have of her were taken several years ago, shortly after restoration. I used the pictures building the hull for my type II, but I didnt use the limber hole arrangement, tower or the deck, because mine is IIA, most likely will be U3 or 7 or 9. Not sure quite yet.
                          Ive picked up quite a few pictures lately but unfortunately not too many of the U boat flavor.Click image for larger version
ID:	75388Click image for larger version
Name:	u534 rusty.jpg
Name:	Vesikko bow closer.jpg
ID:	75381Click image for larger version
Name:	Vesikko bow under.jpg
ID:	75382Click image for larger version
Name:	Vesikko bow under closer.jpg
                            CAD Drawings. They look good. Can anyone see anything out of place or out of proportion?
Name:	Tupe seven bridge closer.jpg
ID:	75547Click image for larger version
Name:	Type 7 closer.jpg
ID:	75548Click image for larger version
Name:	Type 7 bridge closer still.jpg
ID:	75549Click image for larger version
Name:	Type 7 sail.jpg
ID:	75550Click image for larger version
Name:	Type 7 sail arial.jpg
ID:	75551Click image for larger version
Name:	Type seven closer angle.jpg
ID:	75552Click image for larger version
Name:	U16 forward.jpg
ID:	75553Click image for larger version
                              • 1639
                              #314
                              There is more to come.
                                Nice for sure.
