Rolling Your Own WTC Cradles
    I can’t use the installed cradles in my 1/72 Skipjack with the new modular subdriver. Anyone roll their own on theirs? Would appreciate ideas.
    • 13977
    A pencil loaded compass and some 1/4" plywood. Get to it!
      WOOD! In a SUB!?
      Seal the crap out of it BEFORE you put it in and be darned sure you don't drill holes into it or crack it. I'd go with 1/4" plastic sheet, available at a million places online. Sintra is a nice product, not as dense and easy to work with.
        OH Yes! Got to agree with Bob! Wood is for cabinetry, not Submarines!! Sorry David!:-))
          Bob, I was hoping you would see this. I forgot the name of the stuff you recommended. Alzheimer's moment.
            • 2639
            Perhaps Dave thought he wanted a cradle to mount the wtc on when it was out of the water, for maintenance etc.?
              • 13977
              Thanks for the attempted save, Andy. But, no. I meant wood. Consider the application. What's the harm? So what if the wood swells and cracks. So ****ing what??!!
              This guy holds out for RenShape, G10, or depleted Uranium, and since such materials are not readily available he quits the project. Wood is likely at hand; the other stuff -- in most shops -- is not.
              A little pragmatism, guys.
                • 3752
                I used Garolite (fiberglass/epoxy component) to make my cradle mount on the Gato. Worked great, I guess it is important not to get stuck in what you do not have but look for other sources. While wood is not my number one choice, I would not turn away from it if that is all I had.
                To answer his question, I would use the cradles provided, but make a fill in so the 2.5" will now fit into the 3.5" cradle.
ID:	138756 Sorry for the crayon drawing.
                • a1965l
                  • 147
                  I modeled cradles in Autodesk Fusion and 3D printed them. Took a couple of tries to get the fit right, as the hull apparently isn't quite as perfectly round as the computer's perfectly round. If you know the diameter of the hull, and are sure it's round, I can draw a cradle for you, but doing that kind of prototyping is always easier when the designer has the object in front of him, as tweaks are usually needed...
                  • Bob Gato
                    • 898
                    Click image for larger version  Name:	images.jpg Views:	0 Size:	2.7 KB ID:	138779 Consider Azek (PVC dimentional trim board used in common construction)-machines and glues well , takes paint well, is positively buoyant and is relatively cheap -.75x5.5x96 for $20 (available at Home Depot or Lowes) . ...cuts like wood.
                    "not to get stuck in what you do not have but look for other sources."...well said Tom!
                      I ordered 1/4" Sintra yesterday along with some contour gauges.
                        By the way, Dave has always been daring. I heard he once hid in a refrigerator during an atomic bomb blast. By the way, I still can't change my avatar and it's driving me nuts.
