Daily submarine picture
This is a sticky topic.
A stiff breeze blowing down the dry-dock? I agree, it looks tight as a drum.Is it me, or did the sail-loft get that after sheet so tight it looks like there's a pressure differential between inside PJ shroud and the rest of the world?Leave a comment:
The raised access plate foundations suggest that the anechoic material has not been applied yet. The 'purple' is that same shade we see when you mix anti-foul red with black and has been seen between center line and waterline on some post 80's boats.
I would kill to get a peek at the rotor and stator(s).
MLeave a comment:
I note the difference in grey color of the hull and the black upper part of the rudder. Do you have the rest of the picture that shows the upper hull and sail?Leave a comment:
ever wonder about the guys that sewed up that prop cover? They must have a big assed sewing table, and a lot of guys to muscle the material around the shop. Do you suppose they must have big time secret clearances because of all the mesurements they have acess to, as well as the configuration of the Kurtz fairing itself. Just a thoughtLeave a comment:
Here we have a closeup to the closeup. Good thing its high resolution.Leave a comment:
Not a view that you normally see. The only view and entrance is on the starboard side. At least at the Intrepid museum, that is.Leave a comment:
Good view of the top of the sail of the USS BremertonLast edited by greenman407; 01-22-2014, 06:49 PM.Leave a comment:
Ive got a whole bunch of these retouched, colorized Japanese sub pictures. I should post them in the Japanese sub thread.Leave a comment:
the HA 201 was a class of sub, ther were about 80 built at the end of the war, not many saw service. Did about 12kts on the surface and 14 submerged. Was compairable to the German type XXI and XXIIIs The Japanese had the German plans for the double hull and propulsion designs and built their own version. A case of to little too late same as in the ETOLeave a comment:
