1/96 Blueback
    Now the control surfaces are fitted and working. I'm going to fir the shaft bearings and coupler later tonight. Damn rainy here today.
ID:	112188Click image for larger version
      If I knew how to change this topic I would. There is a distinct lack of Blueback here right now. It arrived today, incidently - the Blueback that is. What a great kit. The level of detail is extrordianry in evey respect. My advice is to go and buy one now before they disappear for ever. I'll get onto that in a few weeks. In any case, this little romp should be titled "Kashalot" - or "Uniform" not Blueback. So, onward with the "Not Blueback" build.
      There is a prominent antenna which retracts into the deck at the rear of the sail. I have no idea what its function is but its BIG and LONG so I am assuming that it is an HF antenna of some kind. Anyway its in the right place and the right orientation to be made operational. The plan is to run a control rod along the top of the SD and make the thing go up and down. (I explained this to my wife this afternoon and the look of boredom that crossed her countenance would have frozen a summer lake). I digress; back to the antenna. This is it:
      And this is it in the down position:
      The SD is fitted as well.
      • Davidh
        • Nov 2010
        • 719
        #48
        Scott,
        You really have to produce at least a second boat from these moulds. This boat is too original and unique to be just a one off. I reckon I could sell one (basic hull kit) at the Canberra Sub regatta in March.
        How about it?
        dave
          How about I give you the molds (because you're a good bloke) and you can sell as many as you want?
            • 3452
            #50
            Wow! What scale is this? What SD did you use?
              Its 1/96 scale and a 2" SD fits nicely. In fact its coming along quite quickly. All the internal bits are in now so I am painting it a funny shade of black.
ID:	112199Click image for larger version
ID:	112200Click image for larger version
ID:	112201Click image for larger version
                • 3452
                #52
                As this thing doesn't seem to have bow planes you could use the bow plane servo to raise and lower the antenna.
                  That's the plan man.
                    Almost done. The wire for the rear safety rails is on order but will take a week to get here. Meanwhile, I'll let all this paint dry properly and then trim the boat.
ID:	112213Click image for larger version
                      • 3452
                      #55
                      You could paint a shark mouth underneath the bow at eyes on those bulges...
                      • SSN SonarTech
                        • Jul 2012
                        • 116
                        #56
                        very very nice
                        US Submarine Force: Making the Navy worthwhile since 1900
                          Damn silliest idea I ever heard.... oh, wait a minute, that might look quite good.
                            Meanwhile back in the bunker. I have made the little flap cover that goes over the antenna base and added some bird poo.
                              And I see that you dribbled some rust on it. Remarkable job in such a short period of time.
                                Thanks Mate. Not too much rust - its got a titanium hull afterall.
