Condensation in engineering compartment
  • scubaed1911
    • Jul 2019
    • 45
    So there I was last week. Started out as a good patrol, then submerged boat. Water in battery compartment and engineering compartments. Drained water and allowed each section to dry.
    Powered on boat. Dive planes, level-controller, rudder are responsive. Brushless motors are inoperative. Receiver on boat displays ONLY red LED.
    What's wrong?
    Thanks!
    Ed
    • 13749
    What's wrong?
    Thanks!
    Ed
    Did you take the receiver out of its case/shrink-wrap, blow it down then bake it at low heat overnight? Could be mineral deposits are shorting across a chips contact points on the PCB. Do the before mentioned steps then scrub the chip contact points with a fiberglass brush till they shine. Test. Sing my praises.
    • scubaed1911
      • Jul 2019
      • 45
      David, would you please contact me at 864 361 7510
      • scubaed1911
        • Jul 2019
        • 45
        Thanks for the phone conversation Dave!
        I'm experiencing two issues yet:
        No response from motors for propulsion, and no response from ballast system.
          • 13749
          To be sure it's the receiver that is bad put a servo-setter to the ESC and ballast servo. If they work that way it's a sure thing the receiver is broke. Do those checks and get back to me.
            • Jan 2020
            • 1028
            Possible that if the ESC wires or ballast wires are soldered and you used heat shrink tubing that the water got inside them. I found that as David said blow the electronics with air. Be patient and wait a day or so for all to dry. Also, may need to re program. Also blow out all RX wires and connectors. It is possible that the RX shorted when you powered up before all was 100% dry.
            • scubaed1911
              • Jul 2019
              • 45
              Thanks for the info!
              • wlambing
                • Nov 2020
                • 387
                Having lived in the world of wetted submarine electronics (both 1:1 scale and models) it is also helpful to soak your modules (rcvr, servo, etc.) in isopropyl alcohol after you have uncased them and blown them dry. The alcohol will remove any residual water and mineral deposits from the boards and wiring that may form from the water evaporating. Let the piece get good and wet (say a 20 minute soak), then remove it from the alcohol and dry naturally. Then test it. In a past life we managed to save the taxpayers many $$$$$ with just a little alcohol and some patience.
                  • 13749
                  To buttress William's process with a few twists of my own:
                  Blow out the boards and components with LP air; soak in isopropyl alcohol while scrubbing everything vigorously with an acid brush; blow down with LP air; place on an oven plate, and bake at 200-degrees for a day or two; garnish to suit taste; serve warm. Yummy!
                  After our big flood -- three days submersion in brackish sewer water -- Ellie and I were able to save all the electric motors, and about 75% of the electronic devices. What a mess!
                  Click image for larger version  Name:	DSCF1222.JPG Views:	0 Size:	77.4 KB ID:	150510Click image for larger version  Name:	DSCF1226.JPG Views:	0 Size:	72.2 KB ID:	150511Click image for larger version  Name:	DSCF1229.JPG Views:	0 Size:	84.9 KB ID:	150512Click image for larger version  Name:	DSCF1200.JPG Views:	0 Size:	83.7 KB ID:	150513Click image for larger version  Name:	DSCF1239.JPG Views:	0 Size:	67.5 KB ID:	150514Click image for larger version  Name:	DSCF1196.JPG Views:	0 Size:	61.2 KB ID:	150515
                  • a1965l
                    • 147
                    I'll see your flood pic and raise you:
                    That was Matthew in 2017.. or was it 16? They all run together. I know the joy of finding all your r/c electronics underwater.. and I'd love to say that I salvaged most of them but, sadly, given the other priorities after the water receeded, they didn't make it.
                      • 13749
                      Oh... MAN!
                      You win. You are king of the flood victims. I doff my hat to you, sir.
                      • a1965l
                        • 147
                        And that explains my interest in R/C submarines.... more practical than airplanes, sometimes!
                        Actually, I hate to derail the post further, but that was actually flood number 4 at that house... the worst, by a foot, but not the first.. you would think I would have sold a long time ago, but man it was a great location...
                        • scubaed1911
                          • Jul 2019
                          • 45
                          Thanks for the pics!
                          I replaced seal in aft bulkhead. Several water tests blowing into cylinder hose with no bubbles showing. Condensation problem persists.
                          Kinda frustrated at this point.
                            • Jan 2020
                            • 1028
                            Double check pump tubing connections? Maybe still not completely dried out…..
                              • 13749
                              Is the pump casing itself leaking? Some do. I have a fix for that.
