Today's work on the little Revell SKIPJACK fittings kit
    • 13982
    #226
    File that decal thing away till you tackle another plastic model kit (wish they would join the 21st Century and shift to dry-transfers!).
    I assume you have a 'dumb' transmitter. In that case operate your throttle only with the trim slide. Get a 'computer' transmitter, you cheap so-and-so!
    OK, I now permit you to talk about the little GATO. What's up with that? Start a new thread and make it a proper, dedicated, WIP.
    • crazygary
      • Sep 2012
      • 610
      #227
      Just "recently" bought a Wfly 6-channel TX from Caswell. Don't know if it's "dumb" or not!!?? Unfortunately, Social Security alone doesn't
      allow me to make a lot of indiscriminate purchases, so I gotta pick-n-choose!! Bummer!!
      Have done a little preliminary "fiddling" with the Trumpy Gato. Want to get into it a little deeper before I begin the build thread, cuz I'm
      sure I'll have to set her aside from time to time due to the whims of "You-Know-Who"!!
      I'd rather not let the build drag on "ad-infinitum" with a lot of lag times between posts. I can probably kick it off early next week. Got some forthcoming Lions Club business to attend to shortly!!
      Meanwhile, I'll get a little "mileage" racked up to give me a head start. Looking forward to a fun build!!
      Have a great weekend, M!
      • crazygary
        • Sep 2012
        • 610
        #228
        Hiya, M!!
        Regarding the screw that holds the Skippys upper hull piece to the lower..
        Is that a 2-56 thread?? I know for a fact that it's smaller than a 4-40, 'cuz
        that's the biggest tap I have and it's "monstrous" next that little screw!!
        I'm sure I can just drill it and let the screw cut its own threads, but...
        you know us P.I.A. machinists!! Hah!!
        Thanks, M!
          • 13982
          #229
          2-56...............................
          • crazygary
            • Sep 2012
            • 610
            #230
            Thank you, Sir!!
            • crazygary
              • Sep 2012
              • 610
              #231
              Mornin', M!!
              Bit of a "heads up" regarding the servo box on the 1 1/4" SD....
              For whatever reason, the rounded ends where the tubes attach are a bit oval shaped, which, in turn, affects the o-ring grooves.
              In fitting things for my Gato, I found that the areas in question are about .015" larger from top-to-bottom,
              than from side-to-side. I'm going to "massage" mine so that the O-rings don't have so much excessive compression,
              but was pretty sure that you would want to be made aware of this, just in case someone *****es you out about it!
              Maybe a bit of "mold shift"?? "Murphys Law" for sure!! Hope it's an easy fix for you if you haven't noticed it before!
              crazygary
                • 13982
                #232
                Don't get anal on me now, Gary. The tube mashes the servo-box flange back into the round. Don't sweat the small stuff!
                Proceed.
                • crazygary
                  • Sep 2012
                  • 610
                  #233
                  The tube fits fine, it's the o-ring compression that was the problem-o!
                  Besides, the wall thickness on them thar flanges be pretty "stout", eh?
                  Woulda thunk they'd crack afore ye could "mash" 'em!!
                  I did a little filing in the o-ring grooves and now, when ya look at 'em, they
                  don't look like a 3/32" wide paint line!! Dey wuz kinda fricken TIGHT!!!! Mama MIA!!!!
                  All is well tho', but the linkage is still a PITA!! Hah!!
                  But, ess comin' along, Lucy!! No more 'splaining to do!!!
                  Photos in a while, in the little Gato build thread!!
                  Comin' up on "beer-thirty"!! YEEEhah!!
                  grasshopper
                  • crazygary
                    • Sep 2012
                    • 610
                    #234
                    Hi, M!
                    Just a bit of a "heads up" regarding the motor fit on the 1 1/4"SD.
                    I finally got the UM-1 crystal I've been waiting for, and hooked everything up for
                    test purposes. The motor hangs up quite a bit. It seems that either the motor shaft is a little
                    bent, or the brass shaft extension is! Pretty eccentric!
                    I have a couple of Mabuchi 130s' on hand, and some 1/8" brass rod, so I can make what I need
                    to, but someone else may not be so fortunate!
                    Might could want to test them before shipping so someone else out there doesn't raise a
                    whole lotta hell!! Some peoples money is a little tighter than others. I'm good, tho'!!
                    CG
                      • 13982
                      #235
                      I test 'em before they go out. Would you return it to me so I can find out what went sour. Also, give me your address and I'll send you a replacement unit.
                      • crazygary
                        • Sep 2012
                        • 610
                        #236
                        Thanks, M, but not necessary to replace it!!
                        However, I'll send it to you to check out!!
                        Gimmee a good snail mail address and I'll do a priority mailing to you!
                        Mine is:
                        Gary Vejmola (aka: crazygary)
                        21780 Oak Hill Lane
                        Clovis, CA 93619
                        • crazygary
                          • Sep 2012
                          • 610
                          #237
                          You can P.M. it to me!
                          crazy_gary_573@hotmail.com
                          CG
                            • 13982
                            #238
                            Mine is:
                            21780 Oak Hill Lane
                            Clovis, CA 93619
                            David Merriman
                            835 Holly Hedge Ave.
                            Virginia Beach, VA 23452
                            • crazygary
                              • Sep 2012
                              • 610
                              #239
                              Thanks, M!
                              Will get it to the post office Monday!
                              Am sending only the end cap with the motor installed.
                              Much appreciated!
                              CG
                                • 13982
                                #240
                                Thanks, M!
                                Much appreciated!
                                CG
                                perfect
