bow plane retracts
  • fhouldson
    • Feb 2013
    • 45
    bow plane retracts
    hooked up all my linkage everything worked except for my retrat. Will not rotate enough to raise or lower the retracts. Not enough room to put a longer servo arm on. This is on my gato. any ideas?
    Frank
    • 13923
    Frank
    Do they deploy/retract fully with the upper hull off the lower hull?
    • fhouldson
      • Feb 2013
      • 45
      No .They go 1/4 retract. That's all. Linkage won't travel far enough to make full retract. Upper hull is off
        • 13923
        Please post pictures of what you got -- something is terribly amise here.
        • fhouldson
          • Feb 2013
          • 45
          Hope these show up alright.Click image for larger version
ID:	76489Click image for larger version
ID:	76490Click image for larger version
ID:	76491Click image for larger version
ID:	76492Click image for larger version
            • 13923
            OK.
            Cut away the aluminum tray under the retract servo. Drop the retract servo till the output arm (bell-crank) is at the cylinders maximum diameter. Install a longer bell-crank arm. Send me money. Sing my praises! Register me as a religion!
            • fhouldson
              • Feb 2013
              • 45
              I will go out and do what you said. Will let you know how it turns out. Thank you.
                • 13923
                You'll get there. More than one way to skin this cat.
                • fhouldson
                  • Feb 2013
                  • 45
                  That fixed the problem. I'm happy til the next fix. Going to test wtc in water wedsday, hopfull there will be no leaks. Again thank you for your help
                    • 13923
                    My pleasure, sir.
                    For the in-water test, pull the tire-valve core, put a flexible hose to its body so you can blow air into the SD. Hold a hand at each end so you don't pop a bulkhead off the cylinder, blow into the hose and dunk the SD into the drink. You're looking for bubbles!
                    Keep us informed.
                    • fhouldson
                      • Feb 2013
                      • 45
                      All's good in Lone Grove, OK. Did my wtc in water test today and no bubbles. That's a good thing. Happy camper.
                        • 13923
                        Good. Now something horrible will happen. Brace yourself. And don't forget to put that valve core back into the tire-valve body!
                          • 3727
                          Congratulations! Excellent hurdle to be over....now on to fun things like trim!
                          • fhouldson
                            • Feb 2013
                            • 45
                            going to start putting foam in sunday. What's the best adhesive to use to bond foam to hull.
                              • 13923
                              any air-dry silicon based RTV adhesive/gasket-maker
