USS Nautilus SSN571 STL File Package
  • wlambing
    • Nov 2020
    • 394
    #31
    Usually referred to as the Torpedo Ejection Pump "Barn Door".
      • Jan 2020
      • 1028
      #32
      Ok, printing underway, I will make adjustments to the original files as I go. Did some test prints and believe I will print the model at 894.96MM length.
      Not sure how much of this build I will post, many, many files!
Name:	Image 1-19-24 at 11.31 AM.jpg
        • Jan 2020
        • 1028
        #33
        Not sure why the pic came out blurry!
          • Jan 2020
          • 1028
          #34
          After more testing, will print at 38.44" (1:100) as at a smaller size the walls are too thin
            • Jan 2020
            • 1028
            #35
            Printed example of the models details
ID:	177845 Click image for larger version
              • Jan 2020
              • 1028
              #36
              Is this correct, painting inside the white lines blue/gray? Unsure if I need to extend farther forward? Click image for larger version
Name:	Image 1-3-24 at 8.22 AM (4).jpg
                Not sure if anyone is aware of this, but the files for this sub are on CGTraders
                https://www.cgtrader.com/3d-print-mo...-ssn-571-print
                Might check it out!
                "Firemen can stand the heat."
                  • Jan 2020
                  • 1028
                  #38
                  Primed, ready to paint Click image for larger version
                    • 1628
                    #39
                    Can you tell us how many hours it took to 3-D this boat? Also, what was the percentage of bad prints that you had to start over?
                      • Jan 2020
                      • 1028
                      #40
                      Casey, not sure how many hours as many were determining how much I could reduce the files as I only run my boats in my pool. Once that was determined I had zero bad prints. Used mostly PLA then experimented with PETG.
