Akula 1/144 Scratch built
    • 1618
    #136
    No problem Bart, i hope we can meet, i'll be there for sure, taking the active fleet with me, you still have a couple of months for getting her running, no sweat.
    • bwi 971
      • Jan 2015
      • 940
      #137
      The DC needs a pressure pickup tube the requirements are:
      • It must run vertically for at least 2 inches at the end
      • Open end to be as for as possible to the bow.
      The pickup tube is made out 3/32 brass tube. Soldering the tubes at an 90 degree angle would not be strong enough so I made an corner piece.
      The right angle corner piece is made off 2 pieces of 2,5mm aluminum. Temporary spot glued together to drill the holes and permanently glued together when the tubes were inserted.
Name:	Akula (466).jpg
Name:	Akula (467).jpg
Name:	Akula (465).jpg
Name:	Akula (464).jpg
      The bulkhead pass through is made of an aluminum rod turned down to 5mm and provided with an 2,4mm hole (3/32”). A hole of 5,5mm was drilled into the fwd bulkhead and the stuffing box was glued in the bulkhead with rtv silicone.
Name:	Akula (469).jpg
Name:	Akula (460).jpg
      When I know the exact position of the SD in the AKULA the pickup tube will be cut to the length needed and glued in the stuffing box with RTV silicone.
Name:	Akula (463).jpg
Name:	Akula (470).jpg
Name:	Akula (462).jpg
      Grtz,
      Bart
      "Samuel Smiles"
        • 1618
        #138
        Bart,
        By DC, you mean your depth controller i assume, have also one inside the type VII, it's connected to the front diveplanes, so when the depth is reached it will stear up the divingplanes, so limiting the depth i can reach with my boat, it can be overruled with a switch when driving in clear water.
        • bwi 971
          • Jan 2015
          • 940
          #139
          Originally posted by MFR1964
          Bart,
          It's a sort of depth controller Manfred it will keep my boat at a constant depth, no limitations in depth and it will not interfere when I adjust my depth. But when active it will help me to maintain my depth when my stick is in neutral position. I’m very keen to see how it performs.
          Grtz,
          Bart
          "Samuel Smiles"
          • bwi 971
            • Jan 2015
            • 940
            #140
            Scribing, at last.
            Started with the bottom flood-drain holes.
            Nevertheless I have to open them up afterwards I scribe them first for practice purpose.
            All went well, and I’m pleased with the result, pictures showing scribed lines without cleaning or touchup.
            Grtz,
            Bart
Name:	Akula (471).jpg
Name:	Akula (474).jpg
Name:	Akula (472).jpg
Name:	Akula (473).jpg
            "Samuel Smiles"
              • 13850
              #141
              Good work, sir!
              • bwi 971
                • Jan 2015
                • 940
                #142
                Thks David…......you taught me well…......the stencil prep work pays off too.
                Grtz,
                Bart
                "Samuel Smiles"
                • bwi 971
                  • Jan 2015
                  • 940
                  #143
                  Half a day work......she is turning into a real sub now....slow but steady
                  Grtz,
                  Bart
Name:	Akula (482).jpg
Name:	Akula (480).jpg
Name:	Akula (485).jpg
Name:	Akula (484).jpg
Name:	Akula (475).jpg
                  "Samuel Smiles"
                    • 1618
                    #144
                    Bart,
                    Did you made those copper templates yourself?
                      • 13850
                      #145
                      Bart! I want one of those kits. Let's work out a trade or somth'n!
                        • 1618
                        #146
                        NOOOOOOOOOOOO!!!!!!, finish your Nautilus!!!!
                        • bwi 971
                          • Jan 2015
                          • 940
                          #147
                          Bart,
                          Yes I did Manfred.....took me around two months to make them.....I do not want to be reminded on the part where I transfer all the 2d shapes of the drawings into a shell expansion that I could use to make the stencils.
                          Start laughing this is what I did......I enlarged the plans on my computer till they match the dimensions of my model, transferred the shapes onto a circle that I had drawn to a piece of paper, now I had the real dimensions needed to transfer them to the brass sheet. (the drawings that I have are printed on A4 and glued together, and do not meet the scale).
                          Believe me the opening up was the easy part I use d the milling machine and a handful of 1mm mills. Did I mention that they are EXPENCIVE......so every time I broke one I used all my engine room vocabulary to express my feelings about the event.
                          Grtz,
                          Bart
Name:	Akula (486).jpg
Name:	Akula (487).jpg
Name:	Akula (488).jpg
                          "Samuel Smiles"
                            • 13850
                            #148
                            • bwi 971
                              • Jan 2015
                              • 940
                              #149
                              THANK YOU SIR......... but It's a “one ping only” project David......It's my first sub for god's sake and my first scratch build......are you trying to kill me?
                              And if I had two I would sent it to you without compensation.....this is your knowledge in my hands Sir, I can never pay you back for all the stuff I learned from you.
                              Grtz,
                              Bart
                              "Samuel Smiles"
                                • 13850
                                #150
                                Grtz,
                                Bart
                                Flattery? FLATTERY???!!!!!.....
                                Nice try, pal. How about a hostage exchange: one of the SD's of your choice for that kit????
                                (Pretty please!)
