1/96 ScaleShips Oscar II
    The post is doweled to the hull. Its semi-permanent, meaning that that I can get it out if I have enough will power and the correctly sized hammer. I have to admit that I'm at the "stare and conjure" stage of this build. There are so many possibilities and so much space to work in. I purchased some insulin syringes yesterday ($29.00 for 100!!) which will act as the rams for the periscopes and it occurred to me that I could use these these things all over the boat to open and close all kinds of things.
    Back to reality. This is the fore plane retract mechanism. It came with the kit and is very nicely built and reminds me of the Engle unit in one of my other boats. It suffer some damage on the way to Australia (the solder connecting the plane axles broke away from the connecting plates) so I had to replace the steel axles with brass ones for a more secure connection.
ID:	98517Click image for larger version
      Originally posted by Peter W
      Blimey Scott, that thing not wet yet.....I like the common vertical post for the rear planes/ rudder etc. A lot more room in the back of that than in the Akula.
      Peter
      Not wet yet? Pot, this is kettle, over!
      • Peter W
        • May 2011
        • 511
        I had thought, after your negating the use of scopes on the Akula due to space constrictions, of making the Bow planes on the Akula retractable. I have found a short video of a working set on You tube obviously they are not flick out ones like on the Oscar but are linear and at a a slight angle, lots of engineering though. Are you going to make shutter doors for them ? (This is a serious question)
        Peter the pot.
          That's the plan. I'm off to see the nice plastics guy up the road this morning to buy some sheet for the plane doors and the outer torpedo doors. Do you have a link to the Akula video?
            Todays little effort. Slowly, slowly, catchee monkey.
            • Peter W
              • May 2011
              • 511
              Nice rear end ! And Cod eye hooray ! Will post the video later.
              Peter the Pot
                Any photographs of Cod Eye in your collection Peter?
                  Hatch cover for the Cod Eye and one of the torpedo hatches.
ID:	98545Click image for larger version
                  • Peter W
                    • May 2011
                    • 511
                    Hoping this is the Akula planes video. If not then I haven't mastered my new phone .
                    I have a few cod eye pics, you probably already have them but I will post when I get back on the PC.
                    Peter
                      Workin on dem windows!
                        https://youtu.be/K95RV9RFjes
                        Peter
                        Holy snapping duck ****! That thing has more parts that a Swiss watch..........
                        • Peter W
                          • May 2011
                          • 511
                          [ATTACH=CONFIG]31381[/ATTACH]
                          Show off !
                          That video certainly numbs the mind to the prospect..............but it seems to be a working idea.
                          Not many out there of Cod Eye and I can not find any of the thing up whilst under way. If you need one of the top of the door I have one but..... I thought I had more......I am going off for another look.....
                          Peter
                            Made this snip from a video.....found nothing else.
                              Thanks Men. Looks like this thing extends quite a bit further than my plans show. There also appears to be a flap below the main hinge point that opens outward (which would make a lot of sense since that hinge is a complete *******).
                                Forgot to add the photo.
