Skipjack
    • 13405
    #31
    Originally posted by HardRock
    MERRIMAN! Iron that shirt; get a hircut; and STOP thinking about sex!
    (Mike Caswell will ..... paaaayyyyyy!!!!!)
      He wasnt thinking about sex..........he was thinking about the future Merriman/Caswell enterprise.
      • SSN SonarTech
        • Jul 2012
        • 116
        #33
        I vote sex like all good sailors
        US Submarine Force: Making the Navy worthwhile since 1900
        • SSN SonarTech
          • Jul 2012
          • 116
          #34
          What is a good source of Weld-on 16 cohesive? I can only find the stuff in the blue tube, not the red tube as is shown in many posts. Finishing up on all the flood grates and other holes in the hull. Show get tap to fix stern planes today. I am sure I am going to learn a lot by building this. More pictures to follow.-
            • 13405
            #35
            Check your local plastic supply and fabrication shops. They will have the stuff on hand. Useful for Acrylic, but it's thick formula makes it ideal for broad-area bonding where you don't want a too active product that will evaporate away before you can get the big hull sections in alignment.
            But, wait at least 30 days after you glue up the two hull halves (bows and sterns) -- gotta give the thick solvent cement time to gas off, which will produce a concave surface on the hull pieces over the glue applied areas. Ask Mark about that nasty little surprise. Once you let it settle out, you fill the trenched areas with Bondo and block sand to proper contour.
            • SSN SonarTech
              • Jul 2012
              • 116
              #36
              Thanks, should be able to get some work done this weekend.. no airshow, raining and wife away.
              • SSN SonarTech
                • Jul 2012
                • 116
                #37
                Is there a trick to removing the bulkheads from the SAS? I see the tab on the end where it looks like you could gently pry it open but I want to make sure before I mess something up. Sorry for all the questions but I really appreciate the help you guys provide
                  • 13405
                  #38
                  Bring it over ... we're neighbors. Call me first, 468-4687
                  • SSN SonarTech
                    • Jul 2012
                    • 116
                    #39
                    Thanks David, I will do that. Are you going to be available Saturday? I will call. Thanks again.
                      • 13405
                      #40
                      That'll work. Call first.
                      • SSN SonarTech
                        • Jul 2012
                        • 116
                        #41
                        It appears to me there too much of a gap. I think I should extend the flat to make it more snug
                        • SSN SonarTech
                          • Jul 2012
                          • 116
                          #42
                          [img]
                          Slowly making progress
                            • 13405
                            #43
                            At the universal coupler end (forward) shorten the shaft a bit and extend the shaft set-screw flat as well. With both thrust washers in place, there should be a .003-.005" gap.
                            • SSN SonarTech
                              • Jul 2012
                              • 116
                              #44
                              I fixed the stern planes. First time ever using a Tap. Thank you David!!!
                              • SSN SonarTech
                                • Jul 2012
                                • 116
                                #45
                                David I sent you my e-mail after I got home from your shop on Saturday, Was looking for the info on the event in North Carolina- tried to send a visitor message but it will not let me. Thanks for the visit and all the help you provided.
