Moebius SeaView RC Conversion Build
  • junglelord
    Banned
    • Jan 2009
    • 300
    #121
    post deleted
      • 13941
      #122
      Originally posted by junglelord
      Well it appears that the DVDs stall at a different place each time.
      My brother has some special software for buggy programs.
      Trying to copy these and its freaking SLOW.
      It is not scratches for if it was, it would stall at the same place each time.
      Meanwhile can I have a simple photo of the connecting rods at the front dive plane control arm and another at the attachement to the rear dive planes. Trying to determine the actual shape of the entire connecting rod, front to back as well. In that same fashion, one of the Fair Weather Sailplane control arm connection configuration would also help alot.
      With that I can finish this build.
      Thanks.
      Dean
      I don't have those stills.
      I recommend you buy a replacement set of DVD's from Caswell as I recommended, Dean.
      • junglelord
        Banned
        • Jan 2009
        • 300
        #123
        post deleted
        • junglelord
          Banned
          • Jan 2009
          • 300
          #124
          post deleted
          • junglelord
            Banned
            • Jan 2009
            • 300
            #125
            post deleted
            • toppack
              • Nov 2008
              • 1124
              #126
              Come on David, help the man! :eek:
              I'm starting to feel Frustrated TOO! Devilish
              I would like to help but I've not touched a Seaview yet.
              I just had a terrible thought:
              Maybe no one has a 'Good' way of doing it, so therefore they only have pictures of Bad ways of doing it? :confused:
              Rick L.
              • junglelord
                Banned
                • Jan 2009
                • 300
                #127
                post deleted
                • SteveJ
                  • 56
                  #128
                  Dean
                  The picture you supplied showing the bends pointing to the rear of the Seaview are actually for the bow planes.
                  Steve
                  • junglelord
                    Banned
                    • Jan 2009
                    • 300
                    #129
                    post deleted
                    • SteveJ
                      • 56
                      #130
                      Dean
                      The bow and stern planes are joined together aft using a 3/16 collar. This is dhown on Dics 3 if you can get yours to work.
                      Steve
                      • junglelord
                        Banned
                        • Jan 2009
                        • 300
                        #131
                        post deleted
                        • SteveJ
                          • 56
                          #132
                          Dean
                          The bow plane push rods meet aft forming a "Y" and then are coupled with the aft planes push rod using the 3/16" collar. I have a video capture of it but not sure I can post it without permission from Dave or Mike.
                          Steve
                          • junglelord
                            Banned
                            • Jan 2009
                            • 300
                            #133
                            That helps the old minds eye.
                            Your a good guy Steve.
                            Very kind of you.
                            Cheers
                            I'll drink to THAT!
                            Any guide channels along the inner hull?
                            Thanks everyone
                            Dean
                            PS Mr Merrimans build is a perfect example of his experience. The CG is perfect. Its quite a work of art and science.
                            I cannot say enough about this engineering feat of excellence. Its more then a boyhood dream come true. Its a gift from the God above as I should be in Heaven and not walking or breathing on my own. I did not have all the money for the entire system and thanks to STRINGFLY my birthday is a very happy one. Thanks Mr Merriman, I am 47 and the owner of a working Seaview. In reality its priceless and I know you do not get paid enough. Or at least your worth more then you can charge. I will forever be enjoying my summers, spring and fall, with my Voyage to the Bottom of the Sea.
                            • junglelord
                              Banned
                              • Jan 2009
                              • 300
                              #134
                              Happy Birthday to ME.
                              I'll drink to THAT!
                              • SteveJ
                                • 56
                                #135
                                Dean
                                Happy BI'll drink to THAT!day
                                Looking through disc 1 there are many shots of the inside of the Seaview. Dave goes over the push rods. From what I can see there are plastic tabs about every 3 frames that keep the bow plane push rods in place.
                                Steve J
