Type 212
    I did a primary test, just to see if it will lock the tube, that worked fine, first i want to have a working SD, this way i can conduct real tests.
    Yeah, it's tight, but i've build smaller, like this Marder.
    Did some more work on the 212, drilled open the top of the conningtower and builded up the masts, i even went a little bit further with adding some stuff to the SD.
    This is how she stands now.
    Opened up the conningtower and added the masts, then it struck me, wouldn't it be nice to raise and lower the masts.
    It think it would be a nice addition, prepared the masts and the holes for retracting.
    There is a dutch guy at our dutch forum who made this possible by using a mechanic lift, got to suck his brains.
    Want to use the surplus parts for the bigger SD to reinforce the upper part, why?, since i want to shoot some torps it's easier to not preform the Z cut, allowing a better access to the moving parts in the front.
    After being inspired by the possibility of moving masts my mind went into overload, grabbed the Kilo SD and cannibilised it for some parts.
    Want to place some servo's in the frontpart allowing me to shoot the tubes separatly, i wonder if i'll manage to jam everthing inside.
    I don't know if a SL8 receiver would fit in, i centainly need it with the use of almost every channel.
    1 Rudder
    2 Divingplanes
    3 ESC
    4 Pump
    5 Tankvalve
    6 Peroscopes
    7 Tube 1
    8 Tube 2
    Greetings Manfred.
    Wow! thanks Manfred.
    Have you conducted in-water testing of the float mechanism already?
    Can't wait to see your version of the internal float valve. Kinda tight inside that 2" SD.
    Wow Scott,
    That drawing looks even to me complicated, seen the fact there is a lot of stuff using hinges, there is also a great chance that it will get stuck.
    On request, the close ups.
    Side view of the snorkel tube.
    Top view of the snorkel tube.
    Right side view from the hinge.
    Left side view of the hinge.
    Since this is a prototype i still have to fiddle with this construction, the used material is too thin and will bent easely, have to replace it for some thicker copper.
    The first step was to make a construction to see if the principle can work, now it's refining the construction, allready some idea's about altering the hinge part to be more rugged.
    Removed the flash and cutted the rearpart to fit the X tail, lined her up by looking at the panellines, fixaded her with some tape.
    A total view of this zippy sub, it's fun to build, reminds me of the past when i builded modell kit airplanes.
    Greetings Manfred.
  • Scott T
    Valve looks great. Here is a Rube Goldberg sketch.
    I could not figure out how to use a candle burning
    through a string to activate the valve underwater.
    Scott T
Name:	another valve.jpg
    Originally posted by Reckless
    woot! small boat SAS ... nice Manfred. can you feel all the eyes on you....
    Me too. I want to put one on my Kilo someday.
    Great idea of putting the float body under the deck and not in the tight confines of sail (as I had planned on doing). Now the only thing in there is the snorkel mast.
    This set-up will fit under the square deck of the Kilo nicely.
    Can you post close up photos of your snorkel mast.
  • Reckless
  • oztruck
    Hi Manfred, I have my eyes looking your way as well. Very interesting
    Cheers Chris
    Hat's off to the Chinese for the servoes. The Brit's (Mtroniks) for the ESC. and Kevin McLeod for the small fail-safe-angle-keeper unit (ADF-2) we recommend for these tiny SD's. And those little, super-selective receivers Aroosh makes, the Sombra Labs SL-6 -- perfect for the smaller SD's as well.
    I'm watching you, Manfred! Love the snorkle -- I'm taking notes as you march on with this.
    Thanks Yannis,
    Due to the size, ready kitparts and used SD it's not a lot of work, started it up and will turn my major attention back to the type XVII, just like you wrote, the torpedosystem will be a challenge, it all so cramped up inside.
    Have some idea's of changing the internals of the SD, have to boggle the brains for that, with this size of subs it's amazing how many stuff fitts inside.
    Gotta love micro servo's and micro ESC, those guys who made and designed that deserve a seat in heaven.
    Greetings Manfred
  • bassplayer1
    I see you couldn't keep your hands off this little beauty and started allready working on it Manfred!!! Keep it up!!! I like the idea with the torpedos, it will be a challenge in this scale!
    This evening i started building up the SD, took me 1 hour to finish it up, looked at some pics on the forum and copied that to the SD.
    I thought there was a manual for the kit form SD, pics say enough to me, it's simple and rugged designed, little bit small and you need some fiddling getting the gascontainer in, certainly have to got some long pliers or very tiny fingers.
    Results sofar:
    The complete dryfitt of the SD, don't mind the batteries, just used them for fitting to see which room i've got left.
    I was thinking about the SAS floater for smaller models, and came up with this prototype, using floating body can mean, small and high or flat with more width, this allows you to poke the inlet inside your tower and leave the floatingbody low.
    The underneath of the floatingbody is curved by using sandingpaper, used the SD diameter as a mold, don't know if this will be a proper solution, but i allways try to keeps things simple.
    Greetings Manfred.
    Originally posted by MFR1964
    OK then, it's a go on the tubes, kissing my ass won't speed up the proces, i get distracted, so it will take ages to finish this model.
    Electric one's?, it would be a challenge, have to think about that, if you can miss some gastorps to play with, it would be welcome, by the way, looking at this small WTC gives me the creeps, used to big dry compartments
    I thought you guys at the USA always think big, and no popcorn for you, just nutricias and healty musli.
    Greetings Manfred.
    Manfred,
    Hey, when it's done, it's done. I'm with you on the, 'getting distracted' part. Mike is forever beating me up for not staying on-point with assignments. (I would rather die than admit he's right).
    Sure, I would be delighted to send some gas propelled weapons (in a slow, friendly manner) your way, Manfred. Send me your mailing address and I'll fix you up. Here's my e-mail: dmeriman@aol.com.
  • Reckless
    Greetings Manfred.
    Dems Fightin words! extended modeling pliers at 5 paces, turn and pinch!
    Greetings Manfred.
    You Nut!
    Obviously you don't share Norbert's opinion about torpedo capable r/c model submarines and the charactor of those who drive them!
    No, no problem with shoving the SD back to suite the torpedo tubes, Manfred. You will put the C.G. and C.B. just aft of the sails trailing edge. You compensate for the shifting c.b. (the ballast tank well aft of the C.B. location) with carefully positioned hunks of foam placed below and above the waterline. A flexibility of ballast tank longitudinal placement (to suite requirements like your torpedo tubes) not enjoyed by the fixed in place dry-compartment approach.
    I've got some developmental gas-powered 1/96 torpedoes sitting here not doing anything lethal. You want a few to play with? Or, are you going to employ an electric motor system into those tiny things?
    I'm very jazzed about this -- our SD and kit in your hands. Break out the pop-corn, gonna be a fun show.
    Jeezus ... listen to me: I'm kissing your ass already.
    I'm such a whore!
