Made some progress on the rudder and diveplanes, also some work how to fasten the upper hull part without using tools,
Getting those things in by using tweesers and a lot of patience.
Result is moving diveplanes and rudder.
Made a dryfit with the SD to see if everything worked out as intended.
Placed the rear bulhead with the shaft and control rods for the diveplanes and rudder.
First step in getting me a way to fasten the upper part, used some foil to prefent glueing the upperpart down on the lower part.
