My first build, and I need help!
    • 13948
    #31
    I appreciate the need to unstrap and turn the hull around to make the second cut -- but make sure you maintain the boat 'level' when you do the other side. Go slow. Don't over-feed the blade into the work! The best blade for this is a large diameter, thin, diamond disc.
    You a general aviation buff or an r/c plane nut?
    • beeryboats
      • Jun 2011
      • 124
      #32
      Both! Not to mention RC heli's, boats, and a tank. ;)
      • beeryboats
        • Jun 2011
        • 124
        #33
        The cut was made with just a little stress. I would not recommend the Dremel EZ Lock system. The kerf is a little wider than I would have thought as I think the blade wobbles on the shaft as you cut. It's all cleaned up and ready for the next step but I'm not. Break time!
          • 13948
          #34
          Why, you over-indulgent so-and-so!
          Hey, we get one grab at the apple. Go for it!
            • 13948
            #35
            I should have mentioned that it was best to go with a blade that was fixed to the shank. You're observation is correct: you were a victim of 'wobble'.
            Bet you're glad that's over with!
            • beeryboats
              • Jun 2011
              • 124
              #36
              Ah yes, but another hour of lovely DVD watching has me eager to carry on! David I can't help but smile every time I hear the sound of freedom in your DVDs. You must live near a Naval Air Station by the sound of it. I think it's ironic that I came up with the same deck hold down system for my U505 twenty years ago. Is the filler used in the horizontal seam a Bondo type product? Gawd knows I'll need lots of it..... And let's hope I don't glue the shafts in tight for the third time. I'm almost out of the wife's nail polish remover.
                • 13948
                #37
                Damned right! ... Oceana Naval Air Station. Every day is an air-show. We're (my house) under the second turn of the approach 'S' when the wind is right.
                Glad the DVD's are an inspiration -- that was the intent.
                Great minds think alike, Beeryboats.
                I use the Evercoat Metal Glaze, but their Rage is good too. Get it from (duh!) Caswell.
                  • 3736
                  #38
                  I see it is late to post this, but the site is up again!
                  David, is this the blade you would recommend for he next hull cut? http://www.gyrostools.com/Circular-Saw-Blades,-Miniature---Works-with-*Dremel®-Miniature-Fine-Teeth-Circular-Saw-Blades/c15_43/p437/Saw-Blade-w/Mandrel-Set,-Fine-Teeth-2%22-Dia.--%2382-12015/product_info.html
                  G
                  yrostools was very quick to send the blade I ordered.
                  • beeryboats
                    • Jun 2011
                    • 124
                    #39
                    [QUOTE=Merriman;15489]Damned right! ... Oceana Naval Air Station. Every day is an air-show. We're (my house) under the second turn of the approach 'S' when the wind is right.
                    You spent your youth in subs, I spent my in airplanes. The sound of a round engine or a RollRoyce Merlin always gets me running out of the house for a look. Now I have my own airstrip and nobody lands here...:(
                      • 13948
                      #40
                      [QUOTE=beeryboats;15507]
                      Gear head!
                      Big, high-speed diesels make my XXXXXXXXXXXXXX (disgusting Merriman -- we don't wish to know about your non functioning parts). But those days are long gone (along with my low-frequency hearing).
                      Your own airstrip. I truely hate you!
                      • beeryboats
                        • Jun 2011
                        • 124
                        #41
                        Hey David, I sprung for the brass props from Caswell. How are they adheared to the shaft? CA?-----Oops! I just took the props out of the package and I see they are threaded. Ok, any idea what thread they are? I'm sure it's something I don't have the die for.
                        • beeryboats
                          • Jun 2011
                          • 124
                          #42
                          Arrrg! I got the thrust bearings glued in without glueing the shafts as well. But it looks like I may have one shaft that is every so slightly bent. Great....
                          • beeryboats
                            • Jun 2011
                            • 124
                            #43
                            I've got the Raboesch brass props from Caswell and I don't see any thread dimensions on the package. As they are made in the Netherlands I'm sure they are metric. I have very limited metric anything so I have no way to "figure it out" with a tap set. Can anyone lend a hand with the thread diameter and pitch?
                              • 2628
                              #44
                              I would expect them to be M4 (4mm) thread, which is 0.7mm pitch, with a 60 degree angle.
                              • beeryboats
                                • Jun 2011
                                • 124
                                #45
                                I had no luck at the jumbo hardware store trying to find the correct thread of the props. I do know it's not 4mm and 3mm is pretty loose. I need dog bones and couplers from the hobby shop so I'll take a prop along to see if they can size it for me. I did find the Raboesch catalog online but they make no mention as to what size the props are threaded.
