    Looking good, pal.
    Thanks David!
    I am very happy with the cut lines, no Styrene needed, used Rage in two spots, the magnetic hold down is perfect Click image for larger version
    Looking good, pal.
    Perfect alignment
    Using a brass rod leveled to determine Cylinder Cradle and Thrust Bearing height Click image for larger version
    Off topic, but when ham radio Click image for larger version
ID:	175074 camping is done, on to the XXIII for a winter project.
    I am going to use Prop from Danny,
    Looks like it's 3D printed in resin. Click image for larger version
    Groovy. Easy Peasy.
    Originally posted by Das Boot
    Dave,
    did you add any grates on the bottom of your XXIII? I didn’t notice in Georgia.
    Nope. Just simple, no sweat, open flood-drain holes.
ID:	175035 Click image for larger version
ID:	175036 Click image for larger version
Name:	DSCF4664 - Copy.jpg
ID:	175037 Click image for larger version
ID:	175038 Click image for larger version
Name:	DSCF4667 - Copy.jpg
ID:	175039 Click image for larger version
ID:	175040 Click image for larger version
Name:	DSCF4652 - Copy.jpg
ID:	175041 Click image for larger version
    Dave,
    How small should the limber holes be, L x H?
    Same as the extreme forward limber hole.
    No!
    What the hell were you thinking?
    You thought making the corners within the too tall limber holes at their tops match the form of the corners at the bottom would fix these awful sphincter looking holes???
    Damnit!
    Rebuild with CA-baking soda grout within the holes top edge to reduce their height. Fine-tune the holes with files, sanding sticks, sandpaper twists of #240 sandpaper and god-knows-what to get them to proper shape.
ID:	175007 Click image for larger version
ID:	175008 Click image for larger version
ID:	175009 Click image for larger version
ID:	175013 Click image for larger version
ID:	175014 Click image for larger version
ID:	175015 Click image for larger version
ID:	175016 Click image for larger version
    Oh! Forgot to add these shots to show how to induce a tight radius into strip stock using a pinch-stick. File this trick away for future use. You're welcome!
ID:	175018 Click image for larger version
ID:	175019 Click image for larger version
    You people!
    Talk about anal.
    HAHAHA! Yeah, some people are hard to teach! (me)
    You're a good sport.
