Bringing my first boat to life again
    • Oct 2017
    • 1045
    #46
    November overkill, Vol.1:
ID:	186372 Click image for larger version
Name:	kronstadt-russland-22-juni-2024-art-object-ein-grossmodell-eines-atom-u-bootes-auf-einem-rasen-in-einem-park-2yea6fe.jpg
ID:	186373 Click image for larger version
ID:	186374 Click image for larger version
ID:	186375 Click image for larger version
ID:	186376 Click image for larger version
ID:	186377 Click image for larger version
ID:	186378 Click image for larger version
ID:	186379 Click image for larger version
ID:	186380 Click image for larger version
ID:	186381 Click image for larger version
ID:	186382 Click image for larger version
ID:	186383 Click image for larger version
ID:	186384 Click image for larger version
Name:	kronstadt-russland-16-september-2023-modell-des-ersten-sowjetischen-atom-u-bootes-k-3-leninsky-komsomol-der-island-of-forts-park-kro-2wy10nm.jpg
ID:	186385 Click image for larger version
ID:	186401 Click image for larger version
ID:	186400 Click image for larger version
Name:	kronstadt-russland-16-september-2023-deckhaus-des-ersten-sowjetischen-atom-u-bootes-k-3-leninsky-komsomol-layout-kronstadt-2wxnpfr.jpg
ID:	186399 Click image for larger version
ID:	186398 Click image for larger version
ID:	186397 Click image for larger version
      • Oct 2017
      • 1045
      #47
      November overkill, Vol.2 :
ID:	186404 Click image for larger version
ID:	186405 Click image for larger version
ID:	186411 Click image for larger version
ID:	186413 Click image for larger version
ID:	186415 Click image for larger version
ID:	186427 Click image for larger version
ID:	186432 Click image for larger version
        • Oct 2017
        • 1045
        #48
        And Vol. 3 :
ID:	186446 Click image for larger version
ID:	186447 Click image for larger version
ID:	186449 Click image for larger version
ID:	186451 Click image for larger version
ID:	186452 Click image for larger version
ID:	186456 Click image for larger version
ID:	186457 Click image for larger version
ID:	186460 Click image for larger version
          • Oct 2017
          • 1045
          #49
          And finally Vol. 4 :
ID:	186476 Click image for larger version
ID:	186477 Click image for larger version
ID:	186480 Click image for larger version
ID:	186481 Click image for larger version
ID:	186483 Click image for larger version
ID:	186484 Click image for larger version
ID:	186485 Click image for larger version
ID:	186487 Click image for larger version
ID:	186489 Click image for larger version
ID:	186492 Click image for larger version
ID:	186493 Click image for larger version
ID:	186495 Click image for larger version
ID:	186499 Click image for larger version
            • Oct 2017
            • 1045
            #50
            Last post also showing the 645'/ K 27 subclass with liquid-metal coolant reactor.
              • 13944
              #51
              Wow! such a magnificent series of NOVEMBER photos. I so want to do this beast someday! Thank you for sharing this excellent information on such a historically (and politically) important Cold War submarine.
                • Oct 2017
                • 1045
                #52
                Fin's attached!
ID:	186769 Click image for larger version
ID:	186770 Click image for larger version
ID:	186771 Click image for larger version
ID:	186772 Click image for larger version
ID:	186773 Click image for larger version
ID:	186774 Click image for larger version
ID:	186775 Click image for larger version
                  • Oct 2017
                  • 1045
                  #53
                  Hello! Recently made a new stern insert( that knife-form thing covering the driveshaft) to replace the very heavy original ABS piece.
                  I decided to maintain the method of using two transversal bolts to secure the aluminum stern frame to the mount inside the stern cone (you'll see that in the pictures).
ID:	189207 Click image for larger version
                  In the first place, i only applied ABS sheet to that original part and bolted it down with six M2 sunk screws, but that both looked not nice and did not give me more space between propeller and rudder what is a priority...
                  I cut the old grp-cover from my first attempt of remaking the stern to lenght and used it as a base to build up the sides.
                  The fillets of the stern planes,made from cast PU, were laminated into those sides after aligning and pinning with CA. An M2 bolt from each side, aft of the planes shaft through the fillets, secures the new stern insert to the stern frame and keeps it detachable.
ID:	189210 Click image for larger version
ID:	189214 Click image for larger version
ID:	189209 Click image for larger version
ID:	189215 Click image for larger version
ID:	189218 Click image for larger version
                  The sides were then built up with fibre-enhanced filler. After grinding it to shape, a layer of light weave and fine-filler will produce a smooth surface. The entire replacement will be MUCH lighter than its ABS-predecessor!
                  As said, i drilled both sides of the stern above the sockets of the stern frame, afterwards screwed a threaded rod through it and wrapped some sandpaper atound it to grind the bore to a nice round shape with the socket bore right in center. That was the original method of securing the aluminum stern and allows that whole module to be removed for maintenance. However, the openings for the screws are WAY smaller and will be alike larger floodholes..
ID:	189208 Click image for larger version
ID:	189211 Click image for larger version
ID:	189213 Click image for larger version
ID:	189216 Click image for larger version
ID:	189223 Click image for larger version
ID:	189220 Click image for larger version
                    • 13944
                    #54
                    You have put a great deal of hard, 'innovative' work into this project. You, sir, are a plodder... and I mean that in the most positive sense of the word.
                    You get your hands dirty. I admire that.
                    You and I would be equally comfortable slipping and sliding along the floor of a sausage factory.
                    Expert Plodder
                      • Oct 2017
                      • 1045
                      #55
                      Greetings! I recently added a chin sonar dome, a flat deck and the sail that is receiving some details.
                      The sonar was made from a (lost) foam core.
                      Click image for larger version  Name:	20260606_113344_copy_2040x1148.jpg Views:	0 Size:	54.5 KB ID:	196329 Click image for larger version  Name:	IMG-20260606-WA0002_copy_1920x1080.jpg Views:	0 Size:	57.1 KB ID:	196330 Click image for larger version  Name:	20260606_124746_copy_2040x1148.jpg Views:	0 Size:	66.5 KB ID:	196333 Click image for larger version  Name:	20260606_161413_copy_1148x2040.jpg Views:	0 Size:	71.0 KB ID:	196334 Click image for larger version  Name:	20260606_170029_copy_1148x2040.jpg Views:	0 Size:	51.8 KB ID:	196332 Click image for larger version  Name:	20260606_172928_copy_1148x2040.jpg Views:	0 Size:	65.3 KB ID:	196335 Click image for larger version  Name:	20260606_210114_copy_2040x1148.jpg Views:	0 Size:	61.1 KB ID:	196331 Click image for larger version  Name:	20260606_171128_copy_1148x2040.jpg Views:	0 Size:	51.2 KB ID:	196328
                      The deck was made from ABS sheet, weld glued, the edges were filled. Annoying, the first portion of filler all over the port side would not cure, since i added too little hardener. I had to remove the entire half-cured putty what was both time-consuming and messy...
                      Click image for larger version  Name:	20260607_191558_copy_1148x2040.jpg Views:	0 Size:	58.4 KB ID:	196336 Click image for larger version  Name:	20260607_191453_copy_2040x1148.jpg Views:	0 Size:	60.4 KB ID:	196342 Click image for larger version  Name:	20260606_210151_copy_2040x1148.jpg Views:	0 Size:	55.8 KB ID:	196339 Click image for larger version  Name:	20260610_220339_copy_1148x2040.jpg Views:	0 Size:	60.6 KB ID:	196337 Click image for larger version  Name:	20260610_220305_copy_1148x2040.jpg Views:	0 Size:	66.6 KB ID:	196341 Click image for larger version  Name:	20260613_155723_copy_1148x2040.jpg Views:	0 Size:	65.9 KB ID:	196343 Click image for larger version  Name:	20260706_101327_copy_1148x2040.jpg Views:	0 Size:	61.7 KB ID:	196340 Click image for larger version  Name:	20260706_101550_copy_1148x2040.jpg Views:	0 Size:	62.9 KB ID:	196338
                      After some treatments with fibreglass-filler, fine-filler and sanding i achieved a proper transition to the deck.
                      The sail was then attached with epoxy glue and some more conturing was performed.
                      The new bow is wider than the original part and would no longer match is base. So i glued down a perforated plastic strip at its inner edge so the bow dome would sit in centre again and poured some resin into the gap between strip and bow.
ID:	196348 Click image for larger version
ID:	196345 Click image for larger version
ID:	196347 Click image for larger version
                      Btw, i use clear sticky tape and ptfe grease to isolate the parts against the resin on this model.
                      I also put some glass strip and filler onto the top of the bow to extend the forward deck and create the transition into the bow.
                      Currently, i started detailing the sail with the handrails and some doors and positioning lights. Some windows and the openings of some masts will complete the action.
                      I will try to create a new access to the locking screw in the fwd bulkhead through one of the torpedo shutters so i can close up the centric hole again.
                        • Oct 2017
                        • 1045
                        #56
ID:	196379 Click image for larger version
                        Click image for larger version  Name:	20260706_230228_copy_1148x2040.jpg Views:	0 Size:	57.1 KB ID:	196366 Click image for larger version  Name:	20260706_230202_copy_1148x2040.jpg Views:	0 Size:	58.5 KB ID:	196367 Click image for larger version  Name:	20260706_230251_copy_2040x1148.jpg Views:	0 Size:	51.2 KB ID:	196368
                        I also extended the stern insert to make a "one-piece" cover for the aluminum frame. Originally, several thin ABS plates were used to do so, held in place by tiny screws.
                        Click image for larger version  Name:	20260706_102612_copy_918x1632.jpg Views:	0 Size:	53.4 KB ID:	196370 Click image for larger version  Name:	20260706_102734_copy_918x1632.jpg Views:	0 Size:	52.9 KB ID:	196377 Click image for larger version  Name:	20260706_102713_copy_918x1632.jpg Views:	0 Size:	60.8 KB ID:	196376 Click image for larger version  Name:	20260706_102644_copy_918x1632.jpg Views:	0 Size:	46.3 KB ID:	196375 Click image for larger version  Name:	20260706_102640_copy_918x1632.jpg Views:	0 Size:	46.2 KB ID:	196378 Click image for larger version  Name:	20260706_102635_copy_918x1632.jpg Views:	0 Size:	44.9 KB ID:	196373 Click image for larger version  Name:	20260706_102723_copy_918x1632.jpg Views:	0 Size:	56.8 KB ID:	196372 Click image for larger version  Name:	20260706_101523_copy_918x1632.jpg Views:	0 Size:	56.5 KB ID:	196371
                          • Oct 2017
                          • 1045
                          #57
                          More work on the sail. Also added the front window and the rear lantern with plexiglass inserts.
ID:	196707 Click image for larger version
ID:	196711 Click image for larger version
ID:	196710 Click image for larger version
ID:	196708 Click image for larger version
ID:	196709 Click image for larger version
                            • Oct 2017
                            • 1045
                            #58
                            Hello!
                            With the sail mostly done, i spent some trial and error with how to finish the stern. I thought about making a mold for the entire part and copying it with fiberglass, but on the other hand id have a rather large mold for one job only and i wanted to keep the aluminum frame inside the stern that houses the machinery and makes up the actual stern. i decided to stay with the solution of making fibreglass covers that create the outer, streamlined shell. The transition between the newly made centerpiece (to replace the old and heavy ABS part) and the then still visible aluminum stern was not to my liking and grinding the edges round would result in very thin and brittle edges on the already thin-walled parts. So i made a separate cover with resin and glass for both the upper and the lower stern, entirely encapsulating the metal framework. This also enables me to remove more metal for weight reduction and creates a smooth transition to the hull parts at their seams. The covers will see some more filling and fine sanding, as will the portion around the driveshaft receive a much sharper profile. Very happy with the result, since the design of the stern was one of the major problems with that model from the very beginning!
ID:	197480 Click image for larger version
ID:	197481 Click image for larger version
ID:	197478 Click image for larger version
                              • Oct 2017
                              • 1045
                              #59
                              The front window at the sail was slightly too wide. I taped it and removed the material around both sides. Filler was applied and the surface was sanded back to shape. Not further pictures, but later on on can see it. That window should also sit a bit higher but i'll keep it for now.
ID:	197483 Click image for larger version
ID:	197484 Click image for larger version
ID:	197485 Click image for larger version
                                • Oct 2017
                                • 1045
                                #60
                                The rudder and sternplanes were originally made from aluminum, using nuts and threaded rods as planeshaft to attach them.
                                Click image for larger version  Name:	20260821_235942_copy_2040x1148.jpg Views:	0 Size:	63.6 KB ID:	197488
                                I made replacements from PU last year, using one of my standard molds for raw pieces. Those had a bore for a 2mm shaft, had to drill that open to 3mm. I used a 2mm rod as guidance and a 3mm circular saw from stainless steel. The parts were a bit too small.
                                Click image for larger version  Name:	20260823_164327_copy_2040x1148.jpg Views:	0 Size:	54.2 KB ID:	197489
                                One brass nut and a grub screw for both rudder and one diveplane are resined in. The other diveplane will permanently hold the planeshaft. At each piece, the front and the back end are beeing enlarged by cutting a slit and glueing a fibreglass strip into it. A little more grp restores the shape with only minor sanding necessary.
                                Click image for larger version  Name:	20260823_174930_copy_2040x1148.jpg Views:	0 Size:	61.7 KB ID:	197491
                                Click image for larger version  Name:	20260830_102028_copy_2040x1148.jpg Views:	0 Size:	39.4 KB ID:	197490
                                This produces both strong and lighter planes and eases assembly (to the common standard). WIP.
