Scratch build Skipjack-conversion : Project 1710 Beluga in 1/63 scale
    stern cone from the inside. The step between "old" and "new" hull must be flattened. Will make a large grinding cone with some rough paper on it.
    Not done yet, Bob! Current to-do list:
    - safety tracks, styrene rod or antenna cable. Another radio test will deal with this.
    - trimming the still raw planes to final shape
    - adjusting the stern cone to the prop hub's diameter
    - modifying the raboesch prop cutting back the blades and hub. Make russian hub=counter nut from brass
    - cutting out hull under the sail, laminate sail to hull, finalize sail and deck, sail railing
    - hull filling
    - filling tool marks from scribing and over-cutting of the floodholes
    - linkages and wtc-cradle
    - laminating of the brass details
    -painting
    Right now doing this:
    Gluing down the docking ring and buoy, installing plane shafts ( one is loose !), install the rudder horns. Surplus parts from the MIKE.
    Click image for larger version  Name:	20221210_141529_copy_768x576.jpg Views:	0 Size:	92.9 KB ID:	167648Click image for larger version  Name:	20221210_143323_copy_768x576.jpg Views:	0 Size:	70.9 KB ID:	167647Click image for larger version  Name:	20221210_141657_copy_768x1024.jpg Views:	0 Size:	40.0 KB ID:	167651Click image for larger version  Name:	20221210_145738_copy_768x1024.jpg Views:	0 Size:	40.3 KB ID:	167649Click image for larger version  Name:	20221210_150425_copy_768x1024.jpg Views:	0 Size:	43.4 KB ID:	167650
    Very nice work, but for heaven's sake, sand and fill that sail fillet! That gorgeous hull is looking like a supermodel with a black eye! :P
    Cannot post more than 1 photo at a time! Next step:
    Next step:
    Next step:
    Next step:
    Next step:
    Still having issues with uploading pictures.
    Buoy and docking ring:
    I got my info from a single source, but they could have been wrong or materials are different. Either way, I would be thrilled with your test!
    More details:
    Click image for larger version  Name:	20221130_143855_copy_1600x1200.jpg Views:	0 Size:	45.2 KB ID:	167292Click image for larger version  Name:	20221201_081202_copy_900x1200.jpg Views:	0 Size:	45.1 KB ID:	167293Click image for larger version  Name:	20221201_081232_copy_900x1200.jpg Views:	0 Size:	41.6 KB ID:	167291Click image for larger version  Name:	20221202_221908_copy_1600x1200.jpg Views:	0 Size:	42.0 KB ID:	167294Click image for larger version  Name:	20221202_221927_copy_1600x1200.jpg Views:	0 Size:	48.2 KB ID:	167295
    Click image for larger version  Name:	20221204_151436_copy_1200x900.jpg Views:	0 Size:	51.2 KB ID:	167304Click image for larger version  Name:	20221204_152035_copy_1200x900.jpg Views:	0 Size:	44.0 KB ID:	167305Click image for larger version  Name:	20221204_155852_copy_1200x1600.jpg Views:	0 Size:	51.4 KB ID:	167306Click image for larger version  Name:	20221204_161410_copy_1200x1600.jpg Views:	0 Size:	44.7 KB ID:	167307Click image for larger version  Name:	20221204_161628_copy_1200x1600.jpg Views:	0 Size:	42.3 KB ID:	167308
    That sensor array should actually have 3 of those tubes. However i installed only one for stability. This is 1.5mm stainless steel rod.
ID:	167311Click image for larger version
ID:	167312Click image for larger version
    i also tested the radio - indoor- put the wtc into the hull and closed it up, anntenna at full length insede the boat in parallel to the battery cable for poor conditions. Changed rooms to the other side of the house, doors closed. Wife stood watch at the model. Corona receiver at 40mhz. Many electric devices in the house ON.
    No signal loss not even rattling of the servos.
    Am positively disappointed which causes following question:
    Is this carbon fibre?
    Click image for larger version  Name:	20221203_220709_copy_900x1200.jpg Views:	0 Size:	52.8 KB ID:	167296Click image for larger version  Name:	20221203_220733_copy_1600x1200.jpg Views:	0 Size:	48.3 KB ID:	167297
    Hello! I recently mostly finished scribing the deck details. This evening i milled out the floodholes on the lower hull and made the wing-shaped sockets for those sternward flow sensors from brass, which will be put into recesses milled just forward of the planes. Sidenote i figured my planes beeing slightly too large, but i actually like that look more than the thin fins of the original S-533 so i'll most likely keep'em.
    Click image for larger version  Name:	20221126_211905_copy_1600x1200.jpg Views:	18 Size:	55.1 KB ID:	167134Click image for larger version  Name:	20221126_213059_copy_1600x1200.jpg Views:	18 Size:	52.3 KB ID:	167132Click image for larger version  Name:	20221126_221815_copy_1600x1200.jpg Views:	18 Size:	48.2 KB ID:	167133Click image for larger version  Name:	20221126_221744_copy_900x1200.jpg Views:	21 Size:	48.6 KB ID:	167131
    Trying what works best! Scribing on your kits is much friendlier,David! The 1:1 blueprint makes measuring and marking quite easy. However, i will not implement all the stuff thats on the plan, as in the pictures of the real oat in active duty, there is very little of it visible. There are also several errors in those plans, so i'll always stay with the phographies. Eg forward safety track, there is no interruption on starbord around the docking ring and thereshould not be that towing line from stb sail to the bow. I suspect those rims around the hull sections should not be visible either, but the bow sonar should have clear sharp edges...
    In the end its all black- err... very dark matte grey
    No one here happens to have proper plans or pictures of the bottom and keel and how the lower ballast water inlets were actually arranged? For the moment, i stick with Mr. Hardrocks design, as it makes more sense than the pressluft' boat's.
    will see what happens with my antenna signal, next.
    Jörg
  • Davidh
    Really Impressive Joerg.
    love the attention to detail.
    Dave.
    Forward deck almost done:
    Click image for larger version  Name:	20221120_221009_copy_1200x1600.jpg Views:	0 Size:	43.5 KB ID:	167014Click image for larger version
    Click image for larger version  Name:	20221120_214716_copy_1600x1200.jpg Views:	0 Size:	48.1 KB ID:	167013
