Scratch build Skipjack-conversion : Project 1710 Beluga in 1/63 scale
    Jorg,
    I am still fascinated by what you did with your receiver antenna! Running it outside the boat and utilizing it as a safety tract. I commend you on your forward thinking and ingenuity! As a side note I want to let you know how much I appreciate dentists!
    "Firemen can stand the heat."
  • SSBN659
    Your workbench looks a lot cleaner and better organized than mine. I'm very impressed with your work on this boat.
    Will Rogers
    SSBN659
    Thank you, David! The Beluga's lines are special! Will see how it will perform with the refitted ZB!
    Time for surgery!
ID:	169573Click image for larger version
ID:	169578Click image for larger version
ID:	169580Click image for larger version
ID:	169577Click image for larger version
ID:	169581Click image for larger version
ID:	169576Click image for larger version
ID:	169574Click image for larger version
ID:	169575Click image for larger version
    Safety tracks are installed, will receive a coat of epoxy after filling and sanding.
    Jörg
  • Davidh
    Nice work Mate.
    This Beluga is going to be superb!
    Dave.
    Thank you! Yes, its a sheerline high pressure system, distributed by David Hughes of ZERO BUBBLE MODEL DESIGN. ZB-1 with numerous modifications.
    Hi Jorg,
    Very interesting method of doing your receiver antenna! And looking at the final photo showing your WTC can one assume that your ballast system is forward of your electronics WTC? It is really a joy to see others step outside of the so called box and trying different methods of doing there submarine models. Your Beluga is looking great!
    Hi again!
    Basic scribing of the conning has been re-done. Worked on the safety tracks from styrene rod and tried my approach of an external antenna. Antenna's beeing plugged into the stern endcap, hull halves then closed up. Antenna forms the aft starboard track, reenters the hull at the conning, forms an loop upwards under the conning's ceilling, crosses to starbord and forms the forward port track. To be CA'd down and fixed with epoxy permanently yet.
    Click image for larger version  Name:	20230205_155153_copy_1600x1200.jpg Views:	0 Size:	59.3 KB ID:	169275Click image for larger version  Name:	20230205_153326_copy_900x1200.jpg Views:	0 Size:	47.9 KB ID:	169272Click image for larger version  Name:	20230205_220145_copy_900x1200.jpg Views:	0 Size:	45.3 KB ID:	169273Click image for larger version  Name:	20230205_220136_copy_1600x1200.jpg Views:	0 Size:	53.9 KB ID:	169276Click image for larger version  Name:	20230205_220153_copy_1600x1200.jpg Views:	0 Size:	54.2 KB ID:	169277Click image for larger version  Name:	20230205_220129_copy_1600x1200.jpg Views:	0 Size:	54.1 KB ID:	169278Click image for larger version  Name:	20230205_220304_copy_1600x1200.jpg Views:	0 Size:	50.9 KB ID:	169274Click image for larger version  Name:	20230205_220318_copy_1600x1200.jpg Views:	0 Size:	56.0 KB ID:	169279Click image for larger version  Name:	20230205_220349_copy_1600x1200.jpg Views:	0 Size:	53.7 KB ID:	169280
    Put the model on the milling table and ground the stern to shape. Found an air bubble that was filled with ca and carbon powder. Finalized with wet sanding and the screeding tool. The product is well worth that time consumpting process!
ID:	169053Click image for larger version
ID:	169056Click image for larger version
ID:	169054Click image for larger version
    The prop installed into the stern. Stern taper has been further narrowed by hand. Will remove some more material with the machine as the massive grp cone is quite tough!
ID:	169022Click image for larger version
ID:	169023Click image for larger version
    Final filling and sanding of the conning:
ID:	168982Click image for larger version
ID:	168983Click image for larger version
ID:	168985Click image for larger version
    Imperfections on the limber holes and the gap between docking ring and hull were filled ad brought to shape too.
    The propeller hub received the vortex attenuator, made from 1mm brass, again using the proxxon installation:
ID:	168986Click image for larger version
ID:	168987Click image for larger version
ID:	168988Click image for larger version
ID:	168989Click image for larger version
ID:	168990Click image for larger version
ID:	168991Click image for larger version
ID:	168992Click image for larger version
ID:	168993Click image for larger version
ID:	168994Click image for larger version
ID:	168995Click image for larger version
ID:	168996Click image for larger version
ID:	168997Click image for larger version
ID:	168998Click image for larger version
    Some very creative stuff going on there with your use of the lathe fixtures and high-speed rotary cutter. Neat! I'll file that away for future consideration, sir.
    Some minor filling....
ID:	168505Click image for larger version
    While i left the upper hull to cure, parts for making a new hub for the Raboesch Scimitar Prop arrived. I found a much cheaper and prefabricated alternative to a solid brass bar: lamp-making accessories!
Name:	Screenshot_20230107_232915_Samsung Internet.jpg
    Again, i used my proxon with crosstable to remove the original tip from the propeller's hub. Left hand turning the table's spindle, right hand spinning the threaded rod with the prop on. One clean cut!
ID:	168508Click image for larger version
ID:	168510Click image for larger version
ID:	168511Click image for larger version
    Same treatment for the new nut that will be countered against the prop to secure it on the shaft.
ID:	168512Click image for larger version
ID:	168513Click image for larger version
    Test-fitted in the boat. Not too bad! Will make those vortex thingies from brass and solder them in slots to the hub, next.
ID:	168515Click image for larger version
    Test fitting of prop and planes. Stern tube is in, not yet permanently fixed. Transition between stern and prop needs further grinding.
ID:	168335Click image for larger version
    The hull offers a lot of internal space!
    The taper of the stern needed some final adjustment.
    I made a crude screeding tool. Last picture shows how the stern tube with shaft and prop will slide into the stern.
ID:	168324Click image for larger version
ID:	168325Click image for larger version
ID:	168328Click image for larger version
ID:	168326Click image for larger version
    Happy New Year!
    Didn't get that much done during Christmas Holidays plus cought quite a flew. Now that i'm fit again i was allowed to enter my shop again by my wife and filled up the model's stern to prepare the drive shaft installation.
    First step was opening up the narrow transition point between the original stern and the new longer stern cone. I cut out several wooden discs to make a large and a small grinding drum. Cut a slot into those discs to hold the sanding piper strip that was then wrapped around. That drum was then srewed onto a threaded rod. Forward of the drum the old stern cone master was used to center the drum, another large disc acted as rearward bushing. Powered by an electric drill work was done quickly.
ID:	168306Click image for larger version
    On with the stern tube.
    initially i thought about casting a single large oilite into stern. Dropped that idea and will use a conventional stern tube instead.
    I did not want to simply set the tube in place and cast resin into the stern as i did at the MIKE built because of the large volume that needed filling. Also wantey to enhance the strenght of the rather thin-walled stern. So i stacked up the discs on a 6mm aluminum tube, insulated against the resin with WD40. Inserted into the stern with the last disc using an o-ring and a pice of bycicle tube to form a seal against the inner hull i had the alu tube/ spacer dead center.
ID:	168308Click image for larger version
    Poured in a small portion of resin, than formed a roll from a glassfibre strip and put that down around the aluminum tube, used small rods to condense the glass into the resin. More resin, glass, repeat. After curing i pulled the rod and the wooden spacers, having a rigid fibreglass stern with a clean 6mm bore to accept the actual stern tube.
ID:	168311Click image for larger version
ID:	168310Click image for larger version
ID:	168309Click image for larger version
    Some more work wos perfermed on the upper hull, most notably cutting out the hull under the conning tower and glassing its edge onto the hull.
    Also did more testing with the radio to determine how to install the antenna. Put the wtc inside the hull, attached upper hull and put the boat in one corner of the garden. Left my phone with the model do film what would happen. Went to the diagonal edge of the garden around 80metres away with our house, trees etc in between and i had signal with the antenna inside the hull.
    Video showed some glitches with the radio's antenna all-in.
    Just to make sure i decided to install the antenna on the outside.
    So the antenna was split, employing a stud from 2mm banana gold plugs glued into the endcap of the wtc. Old antenna opening reused for testing of the seals and air venting. Also made a change to the drive gear the needed installation of a new pinion and main gear as well as lowering the engine a bit into the stern bulkhead.
ID:	168319Click image for larger version
ID:	168320Click image for larger version
ID:	168321Click image for larger version
ID:	168317Click image for larger version
ID:	168322Click image for larger version
ID:	168314Click image for larger version
ID:	168318Click image for larger version
ID:	168315Click image for larger version
