1/48 scale Type VIIC U-201 build
  • Monahan Steam Models
    • 755
    #46
    Drove around town this morning searching for a specific piece of material that I needed for the design that I originally had in mind for the aft dive plane linkage. Struck out left and right.
    Decided instead to change the design and just move forward with a simpler design with materials that I had on hand.
    Here is what I came up with today.
    The new part fits like a glove into the stern planes and the inner machined round journals ride smoothly in the bearings that come installed in the abs moldings. No more slop like the original part had. Small 1/16” pins secured in the aft plane supports will interface with the tubes at the outer ends of the planes.
    Planes in the neutral position.
    Up angle position.
    And down angle position.
    Nice and level across both planes.
    The gap between the two hull halves where the pushrod linkage will need to run to connect to the aft plane lever arm is .122” in width. Just a gnats ass under 1/8”.
    The width of the lever arm is .031”. I’m considering using a very short length of .031” diameter wire bent into a typical Z bend to make the connection to the lever arm. This would give about .028” of space to work with after you add up the material thicknesses filling the .122” width slot in the hull. From the short piece of .031 wire I can quickly step the diameter up to 3/32” and then 1/8” once the pushrod travel clears the narrow slot. Or I can cheat a bit and reduce the thickness in the hull halves in this area to open up the slot and use larger diameter wire to start with for making the connection to the lever arm.
    Well that is today’s summary of the small bit of work accomplished.
    Nick
    • goshawk823
      • Oct 2010
      • 262
      #47
      Nick? Where did you get the brass props for the Arkmodel kit?
        Is the stern plane linkage arm premanently sealed in once the hull halves are glued together or you can stlill insert it after?
          • 755
          #49
          Sam, I got them from Bob. He has them available on his site:
          They nice and fit the model very well.
          Nick
          • goshawk823
            • Oct 2010
            • 262
            #50
            Sam,
            Where are you at on your build presently? I know you’ve probably had to deal with some of the same fits I’ve been fighting too, but have you committed to bonding any of the hull sections together? I’m still exploring the horizontal split and tabbing with my build but wondering if you might be able to still do it on your build as well. That being said I will most likely bond the aft two lower hull sections together as there is just too much going on there to not. Same goes for the center section as it is less important to separate now with the easier access. The bow lower sections I may only bond one side to the center section and leave the other to be removed due to all the torpedo junk. Curious on your thoughts.
            HI Nick, my apologies. I just saw this post and your questions to me.
            I have not glued anything up yet...it's basically bolted together and aligned with the pins that on the component pieces. So, all of it can be pulled apart at this time. Since I'm not doing torpedoes, I can permanently bond the forward hull sections, Agree with you about about the center section (nothing much to worry about internally there) and the aft section has so much going on that my plan was to bond all that together too, Ron (R&R Ron) suggested gluing everything together in the lower stern (skeg, rudder support bracket, etc,) there's the two screws there that hold the structure to the hull. I could see scraping the bottom of the pond during a run and having all that rip free. Like you, I had to insert a thin sliver of material (in my case I used styrene) in the skeg to allow the rear planes to travel more freely; I just glued that to one side of the hull half. I have already found that one of the fasteners that is molded into the hull has stripped, so I am really leery of repeatedly taking this thing apart. I am going to try the method you and David have described here. I'm going to have to do it on the Bronco Type XXIII, so in for a penny, in for a pound.
            BTW, I have Oto's PE set for this boat, and I was going to use the PE decks, but decided to go with the kit deck (when I was still following the manufacturer recommended assembly/disassembly method). If I cut along the waterline, I don't have to worry about all the attach/detach tabs that Oto has described; the entire PE decks can be permanently bonded to the upper hull. Using your method makes me rethink what I will use deck wise; the PE stuff is really nicely detailed. I already had build the metal fore and aft sections of the deck and basically abandoned them.
            • goshawk823
              • Oct 2010
              • 262
              #51
              • goshawk823
                • Oct 2010
                • 262
                #52
                permanent in my build, as I'm planning on bonding the aft section together.
                  • 755
                  #53
                  Yes, with this design the shaft will be permanently installed in the hull once the halves have been bonded together. This was not my initial ideal design option but it is a simpler one.
                  Since this this part will be permanent, I chose to fabricate it all in metal and silver brazed all the pieces together for a little more added strength. The plastic dive plane can be slid off of the shaft if needed.
                    • 755
                    #54
                    Sam,
                    It definitely sounds like we have both experienced some of the same discoveries with this kit.
                    I have Oto’s PE set as well. Like you, I was concerned with constantly removing the deck and the possible damage that may occur in doing so. Now that the hull is split at the waterline, I went ahead and bonded all the sections above the waterline together, including the original kit’s deck. I had to be very careful doing this to make sure all the above waterline parts still matched up correctly with the below waterline parts. The assembled upper section is very stout now. Bonding Oto’s PE deck set to the original deck will be much easier than using the tabs you pointed out. Most likely I will cut out and open up areas of the kit’s original plastic deck to work better with the PE deck’s details. In mocking up Oto’s deck to the kit’s original deck I noticed the placement of the conning tower, deck gun and forward deck hatch are in slightly different areas when these parts are compared to one another.
                    This is not a big issue when using one deck or the other by themselves but using them both together does make a slight difference. I’m still accessing a plan forward for this currently with this build.
                    I do like the PE details that Oto’s kit provides for some or the areas on the hull to be corrected. Such as the flooding holes near the propeller shafts and the group of limber holes above the waterline on either side of the conning tower as just two examples. I’m a little bit reluctant however to use these brass PE parts as I’m concerned about the longevity of the PE staying bonded to the hull of a RC model. I’ve considered using these particular PE components as a template to recreate them out of thin abs or styrene sheets and bond those to the hull instead. Just a thought.
                    Regards,
                    Nick
                    • goshawk823
                      • Oct 2010
                      • 262
                      #55
                      Nick,
                      As Bob pointed out in another thread on this particular kit, it’s still a pretty good buy for the money, even with the stuff that we have run into while building it. I have used a bunch of Oto’s parts for the tower and guns, but I’m with you on the pieces he has where you need to heat them into the hull, or inlay them into the plastic. I’m skipping their use altogether. I did notice that the PE decks are off a bit from the kit supplied deck. I’m still debating the options here as well. Ultimately, what I thought was going to be a quick build (like Steve Neill did with this kit), is turning out to taking much longer than I had anticipated. But, that’s OK too,
                        Sam,
                        Regards,
                        Nick
                        Your hesitation to use the PE parts is well founded: Polystyrene and brass/stainless will expand/contract at different rates with changes in temperature. So, with that in mind do the majority of bonding with a flexible adhesive (RTV gasket-making) and break the deck into three or four lengths to provide, 'expansion joints'. The deck will get the most heat variance in the July sun so that is your biggest concern. The inlaid PE limber and flood-drain holes will not be a problem as they are small in size and won't see as much heat flux as the deck will.
                        And do cut away as much of the polystyrene deck as you can for two reasons: First, it will greatly reduce the above waterline displacement, meaning a smaller ballast tank; and second, you reduce the amount of expansion/contraction between the PE deck and what remaining polystyrene deck is left to serve as a foundation for the PE deck.
                        I have spoken ! (rumble of thunder)
                          • 755
                          #57
                          Thank you for sharing this very valuable wisdom! With trying to keep track of and plan for all the things that need to be considered during the build, I had not yet even considered the different expansion rates between the dissimilar deck materials in the sun. I appreciate you bringing attention to this as well as the other valuable tips and advice you’ve shared. You just saved me from a potentially big disaster.
                          That Nautilus looks fantastic! I hope that is one of your personal boats. Looks extremely well made.
                          Nick
                            Nick
                            Ellie and me stopped doing commissions over ten years ago. Out side of the occasional 'help-a-friend-out' re-builds and fixes, what is assembled or built here is MINE!... all mine!!!! I have yet to finish this beautiful kit, but I have got it all trimmed out. https://youtu.be/zRdQ-h9sORE
                              • 755
                              #59
                              That is a really nice running boat. Glad to hear this one is all yours! Very historical boat.
                              I would’ve been tempted to fire some warning shots at those surface targets during that run! We get those same kind of geese here in our pond and when there’s about 20 of them all squawking at each other it gets obnoxious fast.
                                Periscope enema's used to be a specialty at Mount Trashmore lake till the Greenies complained. Answering the age-old question: how high can a duck jump out of the water.
