3D Printed Skipjack from The Nautilus Drydocks
    • Jan 2020
    • 730
    I have finished printing The Skipjack. I printed in 1:96 to accomodate my 2.5” Subdriver. I am now installing the mechanics. The Tail assembly is not yet attached as Drive shaft and Control Rods are being routed. Click image for larger version
ID:	153566Click image for larger version
ID:	153567Click image for larger version
    • Jan 2020
    • 730
    At Bobs suggestion I designed a hatch to allow access to the Driveshaft Dogbone and Control Rod Magnetic Connectors. I also fabricated a guide for those as well. Click image for larger version
ID:	153570Click image for larger version
ID:	153571Click image for larger version
ID:	153572Click image for larger version
ID:	153573Click image for larger version
ID:	153574Click image for larger version
      • Jan 2020
      • 730
      One thing I learned was in scaling the Bayonets. Do not change the thickness as it elongates the “beads” that go into the “locking channel”. Here you see one of the Bayonnet Ring. I notched the Ring to allow the Dive Plane rod to fit above the SD Cylinder. All Cylinder Support Rings and the Bayonets were sized to hold my 2.5” Cylinder. I will be using Automotive Sandable Primer and sanding after Trimming.
      Click image for larger version  Name:	33BB0F08-EED0-410F-8371-74A3D381C828.jpeg Views:	0 Size:	57.4 KB ID:	153577
        • Jan 2020
        • 730
        I must say I am amazed at how well the Bayonet System works. I also oversized the Rudders for better agility. I used Loctite Gel, then West Marine System Epoxy to adhere the Hulls. The Loctite Gel was recommended to me for PLA since it “reacts” with PLA for a strong bond.
          • Jan 2020
          • 730
          If anyone has any idea where I can get 1:96 scale antennas, scopes etc. I would appreciate the information.
            • Jan 2020
            • 730
            Sail Click image for larger version
              • 1791
              Bruce,
              Your Skipjack looks like it came out very nice! I have printed up eight of Bob's (Nautilus Drydocks) boats from his files, and they have all turned out great! Looking forward to see more of your progress reports on your Skipjack!
                • Jan 2020
                • 730
                Printing and assembling air and antenna tubes Click image for larger version
                  • Jan 2020
                  • 730
                  Thanks Rob! Today I am trimming. She seems perfect! I will be conducting pool trials this weekend.
                    • 1791
                    https://youtu.be/0sQJhRoVdhw
                    Bruce,
                    What WTC/Sub driver are you using, or did you scratch build your own? Looks like it worked out well!
                      • 1152
                      How much sanding does it taken to get a smooth surface?
                        • Jan 2020
                        • 730
                        The WTC is a 2.5” Cylinder by the one and only Mr. David Meriman III. Rob can you answer the sanding question as I elected to hold off on sanding until a later time.
                          • 1791
                          I sure will Bruce!
                          Casey,
                          Sanding is not a real priority for me, as I am more into the boats function rather than going to a real scale finish! But to achieve a somewhat smooth finish I start out with 180 grit and work my way up to 220 and 300 grit! From there I use 2 coats of heavy fill primer with 220 sanding in between coats. After the heavy fill I use a standard wet/dry automotive primer and then use wet sanding with 300 to 400 paper. After that, it's all flat finish rattle cans for color (as close as possible to full scale boats) and then two coats of matt or flat clear coat finish!
                          I really have not got into the hard tried and true finish work as of yet! That's a whole new process for me to learn!
                            • Jan 2020
                            • 730
                            Ballast Testing and Maiden Submerged Testing
                              • Jan 2020
                              • 730
                              My beautiful pressure tested 2.5” SD from Mr. Merriman III totally operational as depicted in Skipjack videos. I 3D printed a battery holder.
