Weak Point On 1/72 Skipjack
    • 1161
    The tabs on the dive plane ends always worried me that they would break. Well one did during test fitting. I lucked out and found it. Superglued and used spot putty. Anyone else have this problem?
    • 3547
    Not sure I understand, what tabs? I do not recall any tabs.
      • 1777
      The outside of the dive plane support wing? Yeah, they’re fragile in that scale, and located in a spot prone to bumping...
        • 2122
        Reinforce the area with thin brass sheet or g10, bonded on with JB weld.
          • 12332
          Stern plan operating shaft outboard bearing.
            • 1161
ID:	153910 I have an idea on how to fix the broken part. If it works I’ll post it.
              • 1161
              Little more shaping and I’m done. Click image for larger version
                • 12332
                There you go!
                  • 3547
                  Excellent Casey! Good solution.
                    • 1161
ID:	153914 Thanks, guys. I sanded off the end of the dive plane so what I added would be even with the other side. I then glued a piece of .040 sheet of Evergreen plastic backed by a small strip of .015. Sanded to shape and coated with some spot putty. All done.
                      • 1161
                      Click image for larger version  Name:	C66D204A-9144-4961-AD8F-42DCD40D78C1.jpeg Views:	0 Size:	43.2 KB ID:	154355 The boat was missing the mushroom anchor so I got a rubber mold from Hobby Lobby, some molding epoxy and made one. Final sanding/paint next.Click image for larger version  Name:	8DD98133-EF4A-4838-AD15-9C519E221E2E.jpeg Views:	0 Size:	25.3 KB ID:	154354
                        • 12332
                        Neat! Good fix, Casey.
                          • 2759
                          May I know what this particular silicone mold is called.
                            • 1161
                            The wife and I were shopping and I saw this. It was the answer to my missing anchor.
                            Click image for larger version  Name:	67EC58A8-B468-44BD-97C8-2301648D2319.jpeg Views:	0 Size:	68.0 KB ID:	154359
                              • 1161
                              Next is fixing the gap Click image for larger version
